Old 08-08-2011, 12:49 PM   #1
Sven
Sven's Avatar
1969 C10 8/350 coolant usage
One question I have regarding coolant use. I fill her up, doesn't seem to leak at all, the exhaust isn't an unusual color and there's no coolant in the oil but the coolant level drops during use. I've replaced the hoses, rad cap and thermostat and she runs pretty cool. Well, unless I let her run out of coolant.
What do you think? Anything I should be looking at? I know she's an old lady and deserves to be a little demanding at times, but I don't want her to hurt herself.
-Steve
1969 Chevrolet 4x4 C10 Pickup
Sven is offline   Reply With Quote
Old 08-08-2011, 12:57 PM   #2
Lee H
Lee H's Avatar
Re: 1969 C10 8/350 coolant usage
How much are you replacing and how often? To what level in radiator are you filling it to? These older system find a level about 3 inches below the neck, filling above this just goes out the overflow hose while your driving.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-08-2011, 01:06 PM   #3
Sven
Sven's Avatar
I usually fill to the bottom of the neck, anytime I look and see it low. 3" below would sound about the level it's finding, because when I fill the rad it'll take about half a gallon to fill it completely.
Maybe I'm overfilling? I'll pay specific attention to the level next time and if it's 3" I won't worry about it. Thanks for the info ...
-Steve
Old 08-08-2011, 01:09 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
most likey a pinhole in the radiator ,get a pressure tester and see if you can find the pinhole or crack tank or seam .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-08-2011, 01:27 PM   #5
Sven
Sven's Avatar
OK, thanks. I have some surgery planned on the truck so a little downtime required. I'll pull the radiator and take it to the shop to be checked/tested/repaired.
-Steve
Old 08-08-2011, 01:57 PM   #6
'72customdeluxe
My original motor was that way, no external leak and no water in the oil. Replaced the intake gaskets which helped. Head gasket went shortly after. I would do both
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 08-08-2011, 06:51 PM   #7
cdowns
cdowns's Avatar
people waste alot of coolant by filling when the engine is not up to temp and filling to the bottom of the neck
Old 08-08-2011, 09:14 PM   #8
MagmaJct
MagmaJct's Avatar
I remember reading somewhere, (the source escapes me at the moment), that the level should be about 4" from the filler. However, if you are losing coolant, it's possible you're losing it as steam. When the surrounding air is hot enough, steam is quite dry so you may see no evidence of it.
Performing, or having a pressure test performed would be a wise decision.
MagmaJct is offline   Reply With Quote
Old 08-09-2011, 07:57 AM   #9
MARKDTN
Do you have an overflow bottle? There may be a leak in the hose going to it. As said, a pressure test would be a good tool to help diagnose.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-09-2011, 09:09 AM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Its common for the coolant to stay about 3" below filler when cold. Driving my 5th, 67-72 model, 25 years and alot of miles - its always the same.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
