leaf springs
So i have a need for new leaf springs, my truck is a big 10 and i counted 10 leaves but every part place iv checked has most of 9... what am i doing wriong?
Posted via Mobile Device |
Re: leaf springs
10 leafs doesn't sound right. even the heaviest duty c10's from the factory came with 5 on each side. How rough do you want it to ride?
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Re: leaf springs
My '73 4900 GVWR has 7 plus the overload.
Bruce 73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD http://i56.photobucket.com/albums/g1...Rusti192-1.jpg |
Re: leaf springs
The truck is very mix matched, big 10 cab. Stepside bed, duallie rear. Its a c10 4wd... i have heard of helper springs but i havent hesrd of thrm so i dont know what they would look like. I dint plan on running too rough, plowing in the winter this einter, probably not next, and toeing older cars is biut the roughest im going to do, i was thinking 5 would be plenty but wanted to see ehats up
Re: leaf springs
This is incorrect. My old 74swb came w/the HD pkg which was 8-leafs.
Re: leaf springs
Start by measuring your springs (52 or 56" eye to eye following the arc of the main leaf). If you have 56" springs, you probably have 1 ton springs on there, there is a 10 leaf spring pack rated for 4000lbs, and a 5000lb pack.
If you have 52" springs, you may have extreme duty aftermarket springs, I was looking at leaf springs last week and came across a place that sold springs (52" and 56") for tow truck use. They had some massive packs. Of course, now that I need to find it again I can't. OR somebody at one time added a leaf to the 9 leaf pack, not uncommon if you are trying to haul more on the cheap. 7 leaf 2850 lb springs on my C10. Rides like a truck should =-) and doesn't sag when you are hauling something. Alex. |
Re: leaf springs
I took a real look some fool must have added anither leaf but therres only one added to one side, the other sides only 9 leafs. I think im just giing ti go with 7, it seems like that will do me just fine
Re: leaf springs
Drivers side with the extra leaf? Fat guy owner and/or inbed camper haulers usually have the mixed springs I've noticed.
Alex. |
#9 | |
Re: leaf springs
Re: leaf springs
One of the nice things about the 73-87, just about every combination under the sun, and then some more.
Alex. |
Re: leaf springs
I've attached the GVWR for 1977 C10's and C30's which will give you some idea of spring packs and ratings. For example, my C30 has 9 leafs per side + the overload. If I'm not mistaken the individual leaves are wider and thicker on the heavier trucks, but I may be wrong. I know the perches between a 12 bolt and a 14 bolt or Dana 70hd are wider, so I assumed the springs were wider as well.
I once owned a 1 ton Jeep J-30 that only has 3 leaves per side; they were each about an inch thick and that thing would pack a load as well as my C30. |
| Bookmarks |
