#26 |
Re: The Best Possible Radiator
I just remembered. The clutch on my fan went out a couple of years ago. I snapped a picture of the NAPA box so the next guy knew what part to order.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#27 | |
#28 |
7 would move more air. Just curious - is there a reason you don't want the clutch? (You asked if they make a fan with the same pitch with no clutch.) Only reason I am asking is because the clutch fan set-up worked so well for me. I pulled one out of a chevy in the wrecking yard for 5 bucks. Its the only component not new. Make sure to get 18 inch diameter though so the shroud works. I a running a 19inch with no shroud but it cools just great.
Try the 5, it will probably work great. Changing them is not hard if it does not. |
#29 | |
