Old 08-10-2011, 12:54 PM   #1
camshaftgsxr
camshaftgsxr's Avatar
stiffest lowering springs?
who makes the stiffest lowering springs on the market?
camshaftgsxr is offline   Reply With Quote
Old 08-10-2011, 01:26 PM   #2
dropd80s
dropd80s's Avatar
Re: stiffest lowering springs?
ACME has the stiffest I believe.
J/K. I'm not sure. I'm assuming your talking coil springs. I think they will all be about the same. If I was guessing I would say Eibach probably had the most performance oriented springs. Everyone I know that has had a set has really enjoyed them.
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar
Dropped and LS Swapped SWB 87 Build Thread
dropd80s is offline   Reply With Quote
Old 08-10-2011, 01:27 PM   #3
camshaftgsxr
haha thanks, i think ill start emailing or calling around for spring rates
Old 08-10-2011, 01:36 PM   #4
rwhit57
rwhit57's Avatar
I bought a set of McGaugheys and they were horrible, way too soft. Truck bounced like a super ball. Bought a new set of stock springs, cut 1 coil, problem solved.
rwhit57 is offline   Reply With Quote
Old 08-10-2011, 01:41 PM   #5
camshaftgsxr
i have stock springs right now, ive ridden in a 88-98 on eibachs and it was pretty stiff, are they about the same spring rates as the 73-87 springs?
Old 08-10-2011, 03:42 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
I cut two coils off a set of 1ton springs. Very stiff wasnt harsh.
Old 08-10-2011, 04:38 PM   #7
camshaftgsxr
were they taller than c10 springs before you cut them?
Old 08-10-2011, 04:52 PM   #8
Goldfinger
Goldfinger's Avatar
You could move your spring bracket back to use 1 ton springs.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 08-10-2011, 11:19 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
A bit. I liked the ride height. It came out like a 4" and 6 with flip out back. Handled like a slot car.
Old 08-10-2011, 11:38 PM   #10
lilpoindexter
lilpoindexter's Avatar
I have 2" DJM springs on mine..and they are far too mushy for my tastes. I'd stick the stocks back in after some cutting, but I don't feel like busting the front end apart again.
lilpoindexter is offline   Reply With Quote
Old 08-11-2011, 12:02 AM   #11
camshaftgsxr
What model designation was the 1 ton? C30? That way I know both ways of saying it when I go part hunting
Old 08-11-2011, 02:22 AM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
It started as Cab/chassis turned into tow truck.
