Electrical question?
Where the f are you supposed to hook up any key on power accesories like a radio or guage lights,volt guage, etc... All i seem to have is one terminal open thats constant and one that is nothing? Cant seems to find anything under the hood key on power either,or is key on power for these truck only with truck running? Stumped here.
![]() Join Date: Aug 2004
Re: Electrical question?
There really isnt much if you have the stock "glass" fuses. most folks have hacked up spider webs under the dash. the only place you might find is on the fuse block itself, if memory serves me, there are a couple blade connections to one side of the fuse that may be key on.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
X2 ON FUSE PANEL ! i found a couple key on spade terminals on there!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
On the side end itself of the box on the end of the fuse holders?
on the fuse block itself there will be terminals that you can plug a connector on...take a test light and turn key on and off and see which one is switched.
heres a pic !! on the left of glass fuses theres four terminals and on the right where the green wire is theres a couple more!hope this helps...
It does but none of these were key on,but po had the ignition wires to a push button so when i installed new switch and cylinder i didnt end up using all the pins on the back of the cylinder,i wonder if this is affecting the key on issue?
yep all of them need to have a wire on them. some have a couple on them also.
I had to hard wire it so i dont know which terminal on the switch im missing,have been fixing po wiring fiasco for two weeks,what a mess someone can make.
