Old 08-09-2011, 09:55 PM   #1
Q.8
Q.8's Avatar
new problem,speedocable HELP PLZZZZ
hi guys.
i installed the v8 and manual tranny from 1992 chevy truck.its look that the tranny work with electric cable.so my cable will not work.and i need to keep the original speedo meter.WHAT CAN I DO????
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks
--c30 1966 frame off 5 years restoration ; Finished;
Chevy suburban 1958 restoration ( In progress )
85 c10 "back to original project <Finished> "
81 c10 "back to original ( later) "
85 c10 cattleman edition lifted ( finished)>
K1500 1989 full restoration ( soon )
S10 1991 in progress
Q.8 is offline   Reply With Quote
Old 08-09-2011, 10:13 PM   #2
kf4jfk
Re: new problem,speedocable HELP PLZZZZ
I know on motorcycles that you can buy an cable-to-electronic convertor. I think you should be able to find the same for what you need. I have done a ton of these conversions on old bike restorations in the past. I hope this helps. Good Luck!
kf4jfk is offline   Reply With Quote
Old 08-09-2011, 10:23 PM   #3
TR65
TR65's Avatar
I use the Abbott Cable X. It uses the electrical signal from the transmission and converts it to a motor speed that runs the mechanical speedometer.
Works well. You can also calibrate it to give the correct speed on the speedometer.
http://www.abbott-tach.com/Welcome.html
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-09-2011, 10:32 PM   #4
Slow Build
Slow Build's Avatar
$325. Not a cheap fix.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 08-10-2011, 10:00 AM   #5
Clyde65
Clyde65's Avatar
are you using the NV3500?
The nV3500 from an 88 or 89 has the mechanical speedo
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-10-2011, 08:51 PM   #6
Q.8
Q.8's Avatar
its a 3 speed with granny gear.
Old 08-10-2011, 08:52 PM   #7
Q.8
Q.8's Avatar
x2
Old 08-10-2011, 08:53 PM   #8
Q.8
Q.8's Avatar
can you help me with that? i like the idea.where to search for one? brand or model name?
thanks
Old 08-10-2011, 09:23 PM   #9
kf4jfk
thanks
Q.8 My biggest supplier for these convertors is Dakota Digital. They are a large Digital Gauge company and I have had really good success with their product. I am actually building a chopper for a customer and am in the middle of wiring it up today. Good luck... I will check my catalogs when I get to the shop in the morning and let you know.
Old 08-10-2011, 10:03 PM   #10
TR65
TR65's Avatar
Originally Posted by Q.8 View Post
x2
You didn't say you wanted cheap. I wouldn't have bothered you with a response.
As far as I can tell Dakota Digital has nothing like what you need. If I understand correctly you want to convert an electronic speed sensor on the transmission to run a cable operated mechanical speedometer.
If that is correct then I know of only two solutions. 1. A motor drive like the Cable-X to convert the electronic signal to motor speed to drive the cable. 2. Convert the transmission tail-shaft to a mechanical speedometer gear drive. Either solution is +$300. Check out this thread.
http://ls1tech.com/forums/conversion...onversion.html
If you want cheap, throw in an electronic speedometer.
TR
1965 C10 SWB Fleet
Two owner
Old 08-10-2011, 11:27 PM   #11
Q.8
Q.8's Avatar
will wait.i want to see how motorcycle stuff work with our cars.and i will do it if it work.
TR
mr.your help is realy appreciated.and guess what? if i can not find other way,i will buy this converter.but i dont know how its work? do i need the cable of the current tranny? or my 66 one? i should know every thing be4 i buy it.i think no one here know about this job.so i should learn all about it.thanks again
Old 08-11-2011, 01:57 AM   #12
Slow Build
Slow Build's Avatar
Did I offend you just by saying it's not a cheap fix. I'm just stating a fact. Don't get upset with Q.8 just because he acknowledges my post.
Past GM Trucks:
Old 08-11-2011, 09:41 PM   #13
TR65
TR65's Avatar
If you have a cheaper alternative I'm all for it. I studied this problem for a long time before I concluded that the CableX is the cheapest solution that actually works. Then I studied some more before I broke down and bought it. I was determined to keep all the stock gages working with my LS swap.
This is not a plug and play. It takes some work to mount the box, get the correct length cable, do all the wiring, do the calibration etc. But once that was done I haven't had any trouble with it (about 7000 miles). I can't hear it running either and it is just down below the fuse block.
Here is a picture of it mounted in my truck. You can see the speedo cable coming out of the lower right side. People mount the box in various places, fire wall, inner fender, behind the seat, under the dash etc. The key thing is to put it where the cable can reach the speedometer with the least number of bends, and the bends must be very gentle (big radius bends). I thought being electronics and not sealed it would be better to have it in the truck with me.
It comes with a cable but of course was not the length I needed. I had to get the CableX people to make me a cable to my specific length requirements. They did that quickly.
The cleanest solution is to change the transmission tail-shaft to a mechanical speedo drive but it is typically more expensive and you then don't have the electronic signal for other uses.
Good luck with your build however you decide to do it.
TR
1965 C10 SWB Fleet
Two owner
