Old 08-11-2011, 11:28 AM   #1
superwade57
car trailer winch wiring
I have a 18' car trailer w/ 4' split dove. It has a winch on it I'm just wondering what's the best way to run it? Am I best off running a deep cycle battery or running a set or cables to the truck with a relay wired in somehow or run power through the aux pole on my 7 flat wire plug? Never really had any experience with winches before. Thanks for any help or insight you guys can offer
superwade57 is offline   Reply With Quote
Old 08-11-2011, 12:12 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: car trailer winch wiring
Subscribing - I don't have a winch in my car trailer currently (24' Haulmark) but am looking to add one, and will be interested in any advice here.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-11-2011, 02:09 PM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I used a deep cycle battery on the trailer wire'd drectly to the winch, then a wire from the 7 pin plug to charge it as I drove, work'd good for me.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 08-11-2011, 02:35 PM   #4
Moostifer
a fool with no money
Moostifer's Avatar
what about a ground?
I am in the very process of doing this, and was just going to use my deep cycle, but I like this idea!
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 08-11-2011, 03:34 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
We took an old bent hitch and cut the neck off of it and welded on to the trailer. Bought a holder for the winch that will just slide in to the receiver. This way we can remove it when it is not in use and don't have to worry about theft or elements. The battery is kept inside the tongue box with the connecting wires poked through a hole. We test the battery every so often and charge it when we need to. It gets used about once a month or so at most though, not an every day use type thing.
I think that is about a $300 winch with the mount and everything, the tongue box was $50 and we had the old bent hitch laying in the shop already. We've only had to charge the battery once in a year or so.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-11-2011, 03:44 PM   #6
superwade57
I built a custom tongue box for mine. Out of a couple stainless steel outdoor electrical boxes, big enough to hold a battery plus tools and straps And on the back I welded the top four Inches of another box with lid That drops down to reveal winch. Its stainless. It locks and its completely weather tight. It just seems to pull hard. Its an older winch and the tabs on top of the sides, that hold the bolts to keep the sides true are broken off. And winch sat outside on the trailer before I got it. May be the problem too just wasn't sure if a relay could help. But is there anyway to keep the sides true with out the bolts and tabs? Is there a way to clean or replace the electric motor or brushes? It has two new selenoids on it
Old 08-11-2011, 05:45 PM   #7
79k30dually
I used a WARN rear winch wiring kit, it comes with heavy cables long enough to run to rear bumper, solenoid, control wiring, quick disconnect for the heavy cable connections. I'm using a M8000 warn winch. All I do is flip the switch in the cab, install the winch on the trailer, plug the winch into back of the truck, plug into controller into the winch, and let the party begin. I can get pics if you need them. Good luck, Ron
79k30dually is offline   Reply With Quote
Old 08-11-2011, 06:46 PM   #8
Dunenutt
Newbee
Dunenutt's Avatar
I do almost the same thing. I have a winch cradle almost like pictured above. I slide it into the rear reciever, plug it into the warn harness, and slide the hitch into the winch cradle. So the winch is actually mounted on the truck, and the trailer is mounted to the winch.
Dunenutt is offline   Reply With Quote
Old 08-11-2011, 07:42 PM   #9
79k30dually
Have you ever built a project where you can't see the forest through the trees? Truck-Winch-trailer makes total sense. Thanks, How much weight do you put on your trailer? Ron
Old 08-11-2011, 07:59 PM   #10
Dunenutt
Newbee
Dunenutt's Avatar
Largest load i've had is a 91 F-250 4x4, extended cab, 460, on a 18' flatbed. If I was to pull that load for more than 20 miles or so, I would remove the winch after loading.
Old 08-11-2011, 08:22 PM   #11
79k30dually
I was concerned with the weight on the extension. Thanks, Ron
Old 08-11-2011, 08:38 PM   #12
Dunenutt
Newbee
Dunenutt's Avatar
When I have my camper on, I pull the same trailer with a 28" extension. Anything more than a Jeep on the trailer, concerns me a little.
If I wanted to pull alot with the winch attached, I would build my own cradle out of some beefy stuff. They make the reciever tubes 18" long, stuff some solid 2" into it and weld it up. Then you can mount the winch plate to the tube. Same Idea, just supersized. I wouldn't worry about the reciever too much. You could use equalizer bars, if you wanted to pull crazy weight!
All of my trucks have a front reciever too.
Mine looks like this...
Old 08-11-2011, 11:35 PM   #13
67_SS396
My buddy has a car hauler with a winch mounted under the deck and has a battery mounted on the tongue. I have a gooseneck trailer and plan on welding a receiver tube to the neck. In the mean time, I put the winch in the receiver of the truck and use a spare battery.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
