07-30-2011, 11:13 PM | #1 |
headers for 71 454 4x4?
need headers for my truck i m building and i need to know what ones will work. anything will help. thanks
07-31-2011, 10:15 AM | #2 |
Grease Monkey
Re: headers for 71 454 4x4?
These were the only headers I could get to fit within my budget. I had to do minor frame trimming to fit. I know each truck is different so they may fit perfect for you.
http://www.summitracing.com/parts/HOK-2455HKR/
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
07-31-2011, 10:40 PM | #3 |
Thanks .triming the frame where at ?
Posted via Mobile Device |
08-01-2011, 12:18 PM | #4 |
I used Dynomax Cermacoated headers, part number 86022, designed for the 67-87 BBC 2WD. The headers for 73-87 BBC 4WD would not work in my 69 K20. I had to clearance the frame a bit on the passenger side to make them work.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-02-2011, 12:54 AM | #5 |
Devil's in the Details
I used Doug's D303Y ceramic coated headers for BBC trucks and motorhomes. No frame trimming necessary, but they did hit the passenger side lower shackle bolt on the leaf spring. I actually wound up bashing the one primary tube that was closest flat which seems to have solved the issue for now.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
08-02-2011, 01:07 AM | #6 |
Grease Monkey
I'll try to get a picture for you this week.
08-02-2011, 08:24 AM | #7 |
Thatwould help thanks again . Oh and what did you do for the crossmember?
08-02-2011, 08:26 AM | #8 |
How much are the creamic headers ? Kinda doin it on a budget
08-02-2011, 09:49 AM | #9 |
Grease Monkey
I bought the 67-72 crossmember from DIY4x. For my truck I moved the motor forward 2 1/4" and up 2". I wasn't a direct fit for me. As I said in my earlier post every truck is different. Some have been able to use the stock crossmember and haven't had firewall clearance issues. Spend the time to mock everything up and measure everything to get it just right.
08-11-2011, 11:58 PM | #10 |
Hey chevy 1 ton fun i cant find that cross member . Do you have a part number
08-12-2011, 09:23 AM | #11 |
Grease Monkey
08-12-2011, 05:04 PM | #12 |
Thanks agian man. ill be ordering that soon .
