Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 08-08-2011, 11:57 PM   #1
ls1nova71
ls1nova71's Avatar
67-70 6 cyl 350 turbo kick down linkage
Does this have any value? 250 6 cylinder with a 350 turbo, kick down linkage. I had never seen one before with the solid linkage throttle.
ls1nova71 is offline   Reply With Quote
Old 08-09-2011, 12:12 AM   #2
BMERDOC
BMERDOC's Avatar
Re: 67-70 6 cyl 350 turbo kick down linkage
I think you are asking what the kick down does? If so it does have value. If you are in a higher gear and press on the accelerator hard enough it will down shift to a lower gear to aid in acceleration. Its what some people call "passing gear". I think the solid rod was inliner specific.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-09-2011, 03:09 AM   #3
ls1nova71
ls1nova71's Avatar
Yeah, I know what it does, I was more looking to see if there was any intrest in it. Most 6 cylinders were standard shift, so anyone wanting to put an automatic behind one in a 67-70 would probably need it.
Old 08-09-2011, 07:44 PM   #4
BMERDOC
BMERDOC's Avatar
Ok. Sorry, the way it was worded made it a hard read.
Nick Carter
Old 08-12-2011, 07:52 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
If you are interested in selling this set-up,... look here on post #188.
http://67-72chevytrucks.com/vboard/s...=1#post4841108
Member slick copper is looking for what you have.
Keith
Convert to disc brakes.
Old 08-13-2011, 04:02 AM   #6
slick copper
slick copper's Avatar
sure am! thanks lolife99!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
