Old 08-04-2011, 03:54 PM   #1
b2948kevin
b2948kevin's Avatar
Chevy 230 Engine? Numbers?
Hey guys, I have a 66 C10 that I am working on (see build thread in signature), and I want to know if the engine is original and if not, what the exact specs are on it. I know it's a Chevy 230, but where would I pull numbers to determine the date of manufacture, etc?
I would like to order a rebuild kit for it and I would like to make sure I get the right stuff. Any advice on where to get a good kit would be welcome also
66 Chevy C10 Stepside LWB My Build Thread
75 Harley FLH
84 Mercedes 300TD Diesel Wagon
b2948kevin is offline   Reply With Quote
Old 08-04-2011, 04:37 PM   #2
kieth
kieth's Avatar
Re: Chevy 230 Engine? Numbers?
Man you do not need to worry about changes that engine has been around for awhile, the data tag by the drivers left leg should tell you what the truck came with, here is a link to checking it to make sure what it is. Kieth
this comes from the FAQ section above:
https://skydrive.live.com/?cid=9169a...5CFC6D79%21354
kieth is offline   Reply With Quote
Old 08-12-2011, 06:44 PM   #3
b2948kevin
b2948kevin's Avatar
Thanks Kieth. I'd still like to know what year it is, etc. I suspect that it's not original and am looking for someone with experience with casting numbers.
From what I am reading, it's a tough thing to tell for sure without pulling numbers directly off of the crank stamp.
75 Harley FLH
Old 08-12-2011, 06:50 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Chevy 230 Engine? Numbers?
Chevy Six Cylinder Casting Numbers:
http://67-72chevytrucks.com/vboard/s...d.php?t=356268
Online engine resources (casting numbers, calculators, etc.)
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 08-12-2011, 07:44 PM   #5
b2948kevin
b2948kevin's Avatar
Thanks 1bad62...
Maybe I should qualify my problem a little more clearly. Below are some pictures of what I believe to be the casting numbers for my engine. Are these the correct numbers that I should be pulling? If so, they are not listed in the resources above. This is where I am confused.
348675
GM
78
75 Harley FLH
Old 08-12-2011, 07:48 PM   #6
b2948kevin
b2948kevin's Avatar
Here are some additional numbers that I found on the passenger side of the engine block.
CON2 E224
75 Harley FLH
Old 08-12-2011, 07:50 PM   #7
b2948kevin
b2948kevin's Avatar
Here are some that I found on the intake manifold, I don't know if they're relevant.
343303
GM 37
75 Harley FLH
Old 08-12-2011, 08:06 PM   #8
b2948kevin
b2948kevin's Avatar
I know this is a lot of pics, but I also found this number near the distributor:
CE4 08904
Also, my VIN is C1546Z149943
75 Harley FLH
Old 08-12-2011, 08:25 PM   #9
1Bad62Pro/Street
Ok.... lets see.
It is not in there like you said.
The casting is 348675.
Anyhoot I did find this.
If it is 348675 it says it's a Buick 1976-75 250.
Click below to see.
http://www.enginepartswarehouse.com/...ERALMOTORS.PDF
And look at this:
1973-1976 250
1973-1979 235
1973-1976 250
http://www.jameshalderman.com/data/misc/a1/1.xls
And this:
http://67-72chevytrucks.com/vboard/s...d.php?t=395452
This one has got Ole' 1Bad baffled!
Old 08-13-2011, 10:24 PM   #10
b2948kevin
b2948kevin's Avatar
Thank you so much!!!
Seriously, I really appreciate this. It will keep me from buying a 230 rebuild kit and then having to return it for another. This is a really good reference.
75 Harley FLH
