OK what do you guys think?
You really can't tell too much of a difference, really. I installed some 3/4" lowering blocks on my truck last night. Why 3/4", you ask? Well, I wanted to go a tad lower in the rear, but didn't want to spend $70+ on a set of drop blocks. While under the truck one day, I noticed I still had some U-bolt threads showing under the nuts. I had exactly 3/4" of thread, so I had a buddy of mine at a machine shop make the 3/4" blocks to use up all the threads on the U-bolts.
I like the way the rear looks now, but I feel the front needs to come down about another 1/2" now. Your thoughts? Before: ![]() ![]() ![]() After: ![]() ![]() ![]() ![]()
dazed and confused
Re: OK what do you guys think?
Looks great! I wouldn't have thought it would have made that much of difference, but it sure did.
members met: redbaron69, billsbowtie,nc67 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Always looks good, one of my favorite trucks.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
perfect stance!!! :]
think it looks great good job! cheers, Pat
looks great..
The two most important lessons to wrenchin'-1.The only time you have too much fuel is when you're on fire-2. If something hasn't broken, it's about to-- |
![]() Join Date: Jan 2008
I think it looks great! I think you are splittin hairs to get 1/2". If your rears are larger, they kind of fill the wells. I'd take it the way it is. I have thought of puttin larger tires and wheels in mine, but I would have to rework the tubs and bedsides.( Not going to happen) Besides when you put your big self in it, it probably squats another half inch! LOL Go ahead and have your wife take a pic with you in it, you'll see! Beautiful truck!
Cruzin
looks great don't let a 1/2in bother ya
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Perfect!!! leave her alone!!!
Thanks for all your comments and compliments. At first I thought it looked odd and felt the front should come down some more. That's probably because I'm used to seeing it the way it's sat for so long. After spending all day looking at it, and after reading what you guys have to say, I've decided to keep it like it is. That's why I love this board. It still has a slight rake to it, which is what I was afraid I would lose.
I took a couple better pics yesterday evening. ![]() ![]() ![]()
I was going to say it looks fine cuz the rear makes you happy and it still has rake. So,what drop does it have now and what is the difference in front and rear tire diameters? My project will have all four tires the same and it has a 4/6 drop. I would like to have some rake and am thinking to go with either 4" rear springs or a lower front spring. Larger rear tires would do the trick but I want to be able to rotate since I plan to do some traveling in it.
thats a really nice truck....
#13 | |
![]() Join Date: Feb 2006
I agree, perfect stance, i always prefered a slight rake. that is a beutiful truck you have!
71 chevy cheyenne lwb ![]() http://s321.photobucket.com/albums/n..._tab_my_albums Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote! ![]() |
#15 |
Tim, this puts the total drop at 3.5/5.75. Actually, with the 1/4" spacers and bracket from the ECE Super Track Bar probably puts it right at 3.5/6.
The tires are 255/50/17 Front (27") 275/55/17 Rear (29")
#16 |
i like it the way it currently looks, also.
#17 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Beautiful truck and looks perfect as she sits..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#18 |
///Relaxed Atmosphere
nicely done, i would leave it as it sits now. can i see a picture of your interior if you dont mind ?
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
#19 | |
I personally like a little "Rake" to my Vehicles. Looking at your Front Bumper, it looks fine to me. But then I look at your "Aspect Ratio" above the Front Tire and think it needs to come down some to achiev that rake. You had that Rake going on BEFORE you did the 3/4" drop, but now that you've dropped the rear, the Rake almost looks Flat/Straight across. Hope I didn't confuse you too much. ![]() Roger ADENDUM: I went back and looked at the "After" pictures and it does have that raker. I'd leave it alone. Looks Drop Dead Sexy the way it is now!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#20 |
VA72C10
![]() Join Date: Mar 2008
Looks great!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#21 |
I have to agree it looks really good as it sits. the rake on mine is being bothering me for a while just dont feel like wrenching on it I rather just enjoy it.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#22 |
I really like the look. The stance is great. I like it when the truck is low enough that the tires fill-up the fender, but the whole tire is still visible. You've done a fine job on the project.
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
#23 |
Grandpa in the rustmobile...
looks great both ways matt! Sounds like me trying to get as much as I can without buying U bolts lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
