Old 06-27-2011, 06:08 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Shock Absorber Suggestions
I've decided to leave my truck at its stock height but are going to redo the suspension. I getting the Hellwig Rear Sway Bar for the truck and want to redo all the bushing with the polyurethane ones. I've poked around on Energy Suspensions site and can't find a complete bushing kit for our trucks, does anyone know of anyone that sells a compltete bushing kit for our trucks. Also I found someone on Ebay selling a front pair of Bilstein shocks for our trucks so I emailed and asked if they had the rears as well and they said that Bilstein doesn't make shocks for the back of our trucks. So I'm looking for shock absobers recommendations from you guys and gals.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-27-2011, 07:40 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Shock Absorber Suggestions
kyb shocks is what im using on the front ,coil overs on the back vari shock
http://www.brotherstrucks.com/prodin...number=RGS6372
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-27-2011, 10:04 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have KYB Gas-A-Justs on my K20. Contrary to their name, they are not adjustable.... what they are is a better-than-OEM replacement high-pressure nitrogen shock, and reasonably priced. They're a bit firm at first but soften up as they break in, and then they stay good for a long time.
No affiliation, just a satisfied customer -- I have put them on three vehicles so far.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-30-2011, 10:00 PM   #4
capev86
try LMC Truck for some of the bushings. also, Classic Performance Products carries poly bushings for our trucks.
that sucks about Bilstein....i wanted to get a complete set for my 72 Burb C20
capev86 is offline   Reply With Quote
Old 07-30-2011, 10:07 PM   #5
stich626
wonder what the lenth difference of a 70 shock and a 99 rear is..
bet there is a blisten that will work..
I'll poke around the paper catologs at work..
stich626 is offline   Reply With Quote
Old 07-30-2011, 10:07 PM   #6
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
KYB gas adjust that's all I use and don't use lmc all they sale is junk
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 08-14-2011, 06:43 PM   #7
capev86
that would be awesome. as long as the shocks are approx the same length. figure the mounting tabs/bolts should be the same on many chevy trucks.
i'm wanting the best shock money can buy for a TRUCK. kyb's are ok, but more something i'd use on my old turbo dodge since koni stopped making shocks for that application. plus, the yellow w/ light blue boots match my hawain blue truck and are a classic chevy color combo (they make bowtie tool boxes and soft bags in those colors).
Old 08-14-2011, 07:11 PM   #8
Already Gone
That would be awesome. Maybe the Factory Bilsteins from my 99 Cop Tahoe would work on our trucks.
Old 08-14-2011, 07:16 PM   #9
capev86
fronts should be easy since the front chassis from our 67-72 2wd trucks pretty much continued unchanged until 1987 (1991 for blazer and burb).
the trailing arm/coil spring rear is a somewhat rare bird when most GM trucks had leaf springs. but you would think chevy would have been smart and used as few part numbers as possible.
