Rollin' Old Skool
Edelbrock Victor Series Polished Aluminum Water Pump
SOLD
This is a new, un-installed Edelbrock Victor Series polished aluminum, high-volume mechanical water pump...Fits small block Chevy w/ short water pump (clockwise rotation)...bolts & gaskets not included...i bought this to use on my '66 C-10, however i decided to go with a natural finish pump instead....retails for $250 at Summit Racing or Jegs....if you're interested or have any questions, just let me know....thanks for looking, & have a great day! "These Edelbrock Victor series high-volume water pumps are designed for maximum flow and equal coolant distribution in street cars, race cars, tow vehicles, and motor homes. The aluminum pumps have CNC-machined housings with special one-way internal passages that flow more coolant at higher velocities, even at low engine speeds. The CNC-machined, cast iron impellers are larger than other impellers and have curved vanes that produce greater flow with less cavitation. Other features include heavy-duty roller bearing assemblies built to withstand higher torsional loads, billet steel hubs, & leakproof seals" ![]() ![]() Last edited by likaroc13; 08-14-2011 at 11:17 PM. |
Restoration Virgin!
Re: Edelbrock Victor Series Polished Aluminum Water Pump
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
GobbleStalker Calls
![]() Join Date: Aug 2010
K how do I tell if I have a long or short water pump? Don't want to puchase and find out it won't fit.
Thanks Kevin.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
Rollin' Old Skool
unless previously changed, they changed to long water pump on trucks in '73...so '72-earlier trucks would've had the short pump from the factory
What's the difference between a Chevy short water pump and a long water pump?The following information was found in our Edelbrock catalog. The difference is the length of the hub. Chevrolet used a short water pump on small block passenger car engines from 1955-68, 1969-70 350 Corvettes, and 1955-72 light duty trucks. The dimension from the engine block surface to the water pump hub is 5 5/8". The pilot shaft diameter is 5/8". Long water pumps were used on small block passenger cars engines from 1969-87 and on 1973-86 light duty trucks. The dimension from the block surface to the hub is 6 15/16". The pilot shaft diameter is also 5/8". However, 1971-82 Corvettes have a short water pump with a larger 3/4" pilot shaft. Do not mix and match pulleys from short and long water pump engines because this will cause pulley misalignment. If you can fit your hand between the water pump and the block, You have a long style water pump. check out post #18 http://67-72chevytrucks.com/vboard/s...d.php?t=262510 |
GobbleStalker Calls
Can you please check shipping to 13601.
Rollin' Old Skool
Rollin' Old Skool
sorry, i just realized i quoted wrong...i didn't realize you're in Canada....can you give me the full mailing address, and i will check other mail carriers....thanks
actually, i guess you were having me send it to a different US zip code above...sorry, i was confused Last edited by likaroc13; 08-14-2011 at 11:35 AM. |
#8 | |
GobbleStalker Calls
I will PM you when I get home Monday.
