Closed Thread
Old 08-14-2011, 11:52 AM   #3601
Dinos63
chevy only
Dinos63's Avatar
Re: What did you do to your truck today?
got my truck back on all fours, brakes ,fuel, air lines done
CHEVY ONLY... Nothin Else !
Dinos63 is offline
Old 08-14-2011, 11:54 AM   #3602
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Dino
Looks Great!!
LeftCoast32 is offline
Old 08-14-2011, 11:55 AM   #3603
markeb01
Senior Enthusiast
markeb01's Avatar
That is so impressive!
markeb01 is offline
Old 08-14-2011, 05:23 PM   #3604
jbgroby
jbgroby's Avatar
Got the fenders back from the painter yesterday, looking sharp. If you look at the back side of the fender you can see all the small nick where I figure somewhere along its life must have been in a fender bender.
jbgroby is offline
Old 08-14-2011, 05:41 PM   #3605
awbrown
Well I took ol'blue out for the longest ride I have been on since I have had it on the road.. The wife and I did 100 miles ,and ol'blue made it home .. Even drove through a drownpour and neat lightening show...wipers are next on the list ......
awbrown is offline
Old 08-14-2011, 05:45 PM   #3606
markeb01
Senior Enthusiast
markeb01's Avatar
Your painter does great work!
markeb01 is offline
Old 08-14-2011, 06:22 PM   #3607
scooterskoolkustoms
scooterskoolkustoms's Avatar
was a lazy day after yard work I turned the hose on her and washed all the dust off of the old girl,then I took the front fenders,hood,rad support off.need to finish putting plug wires on and start her up after new head gaskets.O well time for a beer there is always next weekend.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 08-14-2011, 06:31 PM   #3608
bo-w
i searched the net for an affordable disk brake kit (with no luck) for my 66 I'm picking up next weekend .
bo-w is offline
Old 08-14-2011, 09:14 PM   #3609
Red65C10
Red65C10's Avatar
Almost finished up the rear main seal replace I started yesterday. Need to torque pan bolts, put filter and oil in and fire it up.
Billy
65 C10
............................... ____
................ ________-|___\____
.;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________
P.S. Send truck money !
Red65C10 is offline
Old 08-14-2011, 09:23 PM   #3610
lwb66step
lwb66step's Avatar
Installed new distributor, coil, rotor, cap, wires, plugs, set timing, repaired my fuel line, GOT MY NEW 63 started for the first time!!!!!! Unfortunately I still can't figure out the fuel issue, the carb is still dry. All I can think of is replacing the fuel pump. But what a relief to hear the engine start. The truck didn't run when I bought it so I am pretty happy not to have to replace an engine.
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline
Old 08-14-2011, 09:44 PM   #3611
yote1234
yote1234's Avatar
removed and polished my t3 headlights! really!
waiting for my stock speaker so i can install stock radio/speaker...
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline
Old 08-14-2011, 10:27 PM   #3612
samuellg1977
samuellg1977's Avatar
Originally Posted by markeb01 View Post
Do you know what type or brand you have? I still have the installation instructions for mine. It's called an UltraCruise II by Rostra Precision Controls, which may or may not do you any good depending on what you've got.
Hey, Mark:
Today I went outside and pulled the cruise parts out and guess what - They won't even fit between the motor and firewall... Oh well, chucked it out... It was the factory vacuum operated thing from the suburban that I pillaged the engine, tranny, and rear end from.
Sam
samuellg1977 is offline
Old 08-14-2011, 10:29 PM   #3613
64GMCHorsepower
Justified!
tightened up all my bed bolts, welded a filler for the gas fill place, worked on my interior, and checked everything after doing the rear axle flip and installing a c-notch.
Everything is looking great! Getting ready to make this my DD for awhile.....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline
Old 08-15-2011, 12:00 AM   #3614
samuellg1977
Thinking of doing that... Have you got pics of the rear axle flip? PM for email.
Thanks.
Sam
Old 08-15-2011, 09:31 AM   #3615
HEI451
Today, CB radio install, made a bracket that sits on the floor for the CB, holds CB/mic. Later, welding the cross bard for my rear facing trailer hitch receiver box onto frame, and mounting the box, moving the license plate, adding a slider hitch receiver holder and chain loops.
HEI451 is offline
Old 08-15-2011, 05:10 PM   #3616
64GMCHorsepower
Justified!
Thanks.
Sam
Not of the actual process....but I can take a couple if you want to see how everything went together.....
Chad
Old 08-15-2011, 09:13 PM   #3617
Vernski
I got my DJM springs yesterday and installed them today looks a little better 3" closer to the ground....Vernski
Vernski is offline
Old 08-15-2011, 09:50 PM   #3618
willyp
willyp's Avatar
vern lets see a shot from the side..
The price of cool aint cheap.
willyp is offline
Old 08-15-2011, 09:53 PM   #3619
losthope
losthope's Avatar
dino i love your garage wall!!! somebody has some graffiti skills....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 08-15-2011, 09:55 PM   #3620
bubba327
HOW long until spring??
bubba327's Avatar
Vern Are you gonna use it for snow plow??? You need a little room to go Over the drifts!!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline
Old 08-15-2011, 10:23 PM   #3621
markeb01
Senior Enthusiast
markeb01's Avatar
That looks great! Did your truck always have the chrome grille or is that a new addition?
markeb01 is offline
Old 08-15-2011, 10:24 PM   #3622
samuellg1977
Cool, thanks. This is my Mabel. She's my dailyrun-about now. Still looking to make some changes without breakin the bank or breakin the truck. Thinkin about some Hot Rod Flatz BLACK with Tan interior. Idunno though. Still having fun driving it.
Sam
Old 08-15-2011, 10:29 PM   #3623
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: What did you do to your truck today?
Still working on my bed.
Cut the mini tubs out.
Going to use stainless steel tubs.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 08-15-2011, 11:16 PM   #3624
Rich 5150 69
Rich 5150 69's Avatar
Just put on a 6 blade factory steel fan and just ordered a new alum three row rad from champion, next wil be the fat block.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 08-16-2011, 12:21 AM   #3625
Vernski
Well Frank will spend most of his time in the shop next to the stove with me with my feet up when the white stuff is outside [my wife calls the truck Frank]...Vernski
Vernski is offline
Closed Thread
