Re: Still up in the air....
Really good points. I already have the rear end set up with the 3.90 rear end. What kinda top speed would I be looking at if I stayed with the six and the mono jet?
#2 | |
![]() Join Date: Oct 2009
your current trans top gear has a 1:1 ratio (stock 3-speed & 4-speed manuals, TH400, TH350, PG, etc). All overdrive trans have a <1:1 ratio, thus the better mileage and ability to run at higher speed for lower rpms. As an example - let's say you have a 235/75/15 tire - it's about 29" tall - and a 3.90 rear - based on the calculator, you would be turning 3160 rpm at 70 mph (whereas with your 4.11, you'd be turning 3330 rpm at 70). In other words, the difference between a 3.90 and 4.11 will almost be unnoticeable. Regardless of tire size - the relative (%) difference between cruising rpm will be the same small ratio when comparing a 3.90 to a 4.11. http://www.carforums.net/rearcalc.php Here's another calculator that you can use to calculate changes as the result of using an o/d trans: (this is also a great ref for what several different transmissions have for gearing) - for top end, only the final ratio and your rear end matters - http://www.angelfire.com/fl/procrastination/rear.html So, as a comparison - with the same tires (29" tall) and same 3.90 rearent, a 700R4 at 3100 engine RPM equates to 97 mph!.... (so,. to your quesiton - your 6 cyl and monojet may preclude that...) Or more appropriately put - instead of cruising at 3100 rpm to get to 70 mph with a non o/d trans and a 3.90 rear, you only need 2200 rpm to go 70 mph. Start counting the gas money $ you'll be saving now! Anyway, hopefully these calculators will help you decide. Also concur with the above comment about a modern eng/trans combo transplant - very good point if you don't mind goin modern. Personally, COMPUTERS scare me.... (on cars, anyway). But it is a good option. A bit more of an involved swap, but many have done it before, so am sure you could also. |
60-66 Nut
I wouldn't bother with switching from 4.11's to 3.90's. There really isn't anything to be gained. If you decide to go with the 396/TH400, I would change the rear gears to a 3.08. The BB will have enough torque to pull the taller gear, and it will be more highway friendly. If you stay with the I6, and install the 700R4, I would suggest a 3.42 rear gear. The lower 1st gear of the 700R4 will help get moving with the I6, and you will have a nice low highway cruise rpm in OD. Of course this is dependent on your selected tire size.
"Where were you in '62?"
![]() Join Date: Jul 2004
Being a Hot Rodder that I am I would say 396.
But you need to check to see how much it will cost you rebuild a stock 396. It suprised me. And i was wanting to hop it up! I was offered one once from a friend.... till I seen how much it would cost to rebuild it just stock, heads and all!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
