Old 08-15-2011, 12:18 AM   #1
Silverray76
Silverray76's Avatar
Smile 400 help
Hey guys so i found a 400 sb for sale its just the block, no internals. I plan to build it form the ground up and i would like some tips from a more experienced builder. I would like this motor to but out at least 475-550 or anywhere between that. The person who im buying it off of said it original and has never been resurfaced which means Im going to have the block resurfaced. Now Im going to go some kind of racing pistons also it there a specific bore size i have to go to? and would be great parts for the motor. Opinions would be helpful or recommendations.
1976 c10 stepside 350/350 My baby
1991 suburban 1500 350/700 The hauler
Silverray76 is offline   Reply With Quote
Old 08-15-2011, 01:24 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 400 help
Measure the bores with a caliper. Drill some steam holes. By resurfaced, do you mean bored out? Resurfaced is a term mostly for head milling/surfacing. The deck should be flat to mount the head. Are you going to use aluminum heads? Even good Vortec heads will have trouble at the 475 HP range. You need to plan out your parts carefully, or buy a kit with everything. Post/move this post over the engine forum.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-15-2011, 02:10 AM   #3
Hazieview
Building Dreams out of Dimes!
Re: 400 help
I have just recently finished building my own sb400. It was my first time to ever build an engine.
In order to give you more feedback I'd have to know more along the lines of what your budget is.
If I had I choice to build mine over again I would get a totally balanced and forged bottom end! These engines make a lot of torque in a very narrow rpm range.
Also dont expect to get too much HP out of an sb400. They are torque monsters!
DO NOT GET A HUGE CAMSHAFT!!!
From the research I have done the gains of a sb400 after 5500 rpm is very minimal. So you want to get as much power out of one as you can from 0-5500. That is where you need to spend your money.
With a stock bottom end, cast heads, air gap intake, 650cfm carb, I was told I should be making around 580lbs of torque. Not sure how accurate this is but I'll be putting it on the dyno as soon as I get the rest of my truck bolted up.
I would not rebuild a sb400 unless it was a two bolt main. (The 4 bolt main sb400s are not usually strong enough to handle near as much power. Just my opinion.)
DRILLING STEAM HOLES IS A MUST AS STATED ABOVE!!!
I would not bore a sb400 more than 60 over. If you ever bang out a sb400 that is bored 60 over you might as well start looking for a block and throw yours in the scrap metal bin. I went 30 over just in hopes that if I do make a mistake somewhere I still have a chance to go 60 over with it.
Now I'm not a professional racer, engine builder, or anything like that. I'm a guy that likes cold beer and nice chevys. However I've taken a lot of good advice from very knowledgible people. A lot of them you will find on this board.
Every man has different theories as to how one should build an engine. Which theory you choose to believe is your own.
Good luck man! Take care!
(just my 2 cents dont take this crap for gospel)
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 08-15-2011, 02:30 AM   #4
Silverray76
Re: 400 help
Its a original block from what im told so i guess it has a stock bore. Drilling steam holes? Ive never heard of it yet im willing to learn. Im not to sure what heads im going to use yet i might go aluminum. This is the part where i go to experienced builders to give me advice
Old 08-15-2011, 02:36 AM   #5
Hazieview
Re: 400 help
What's your budget? I got over $6000 in mine just to give you an idea. That's with my stock bottom end and cast heads.
SB400 350th
Old 08-15-2011, 02:48 AM   #6
Silverray76
Re: 400 help
My budget is a bi weekly paycheck. I make about 1800 a month. The block is a 2bolt main. Now my bottom end wont be stock I plan to buy a new crank and race piston,cam rods ect. Now you say drop my money into the 0-5500 range.. Now do you mean the low end? Now i was planning to bore about 40 over bad or good? what parts would you rec? I was going to go comp thumper cam and a entire comp lifters,rockers,ect.
Old 08-15-2011, 03:30 AM   #7
Hazieview
Re: 400 help
I'm a little confused man. Sorry...
If you are wanting to go with a different crank, rods, and 'racing' pistons I would recommend a full scat rottating assembly.
$1,852.95
Scat Engine Rotating Assemblies(this kit is for an sb400 bored 40 over)
40 over is good. However I would recommend 30 over because it's just more common.
I would not get a thumper cam. It sounds good but you kind find other cams that will produce power way more effeciently.
When I say 0-5500 there are parts out there that are designed with this particular range in mind. Look up various intake manifolds, camshafts, etc. Most of the time it shows you their power range. My engine is actually designed to make its power from 1500-6500 rpm. However I have a 2200 stall converter so it works well with my application.
I would also recommend using your stock bottom end if nothing is wrong with it. That's what I did. I got new pistons and used my original crank and rods. I then spent more money on the top end.
For what you are saying you want it is going to end up costing you around $10,000 or so. I highly recomend creating a budget so you can come up with the total amount you want to spend on your engine.
My total was $3,000 tops... I ended up spending $6,000 and still have a stock bottom end...
If you want to play you have to pay!
SB400 350th
Old 08-15-2011, 05:16 AM   #8
gchemist
gchemist's Avatar
Re: 400 help
Buget an issue? DESTROKE IT!!
Old 08-15-2011, 09:26 PM   #9
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 400 help
i would leave it stock stroke, although there is nothing wrong with a 377 ( i have one) a 406 is better suited to our flying barns,
for 420-450 hp use some flat top pistons with about a 9.2:1-95:1 compression ratio so pump gas is an option. get some aftermarket iron heads( dart/world) or scoggin dickey modified vortechs. a comp cams magnum series cam, with matching valvesprings, and roller rockers, scat rotating assembly (dont need forged yet) with SCAT i beam rods NOT STOCK RODS! have your engine magnafluxed tanked and bored .30 over and TORQUE PLATE HONE! throw on your 4bbrl of choice in an single plain high rise or victor jr dual plane airgap msd street fire distributor
500-550 hp, use the same top end, but change heads to edelbrock perf rpm or afrs aluminum and raise the compression to 10.5:1-11:1 still use the .30 overbore and honing/ magnaflux, add deck milling and a line hone as good options for thouroughness, get a scat FORGED crank, FORGED pistons of choice of your brand ( I Like ross) and MAYBE I beam rods from scat or h beams if you want to beat the **** out of that engine, get a nice spendy crank dampner and then finish with a hamburgers oil pan (#1088) melling HV oil pump, msd billet series hei. msd 6al (for rev limeter, your going to need it) full roller rockers of your choosing. (pst... harland sharps) and the cam should be a SOLID flat TAPPET or roller that is big, (530-545 lift) also add a windage tray
as always i recommend you call comp cams for the camshaft selection as they will set you up with a good choice cam from the getgo
thats how i build my engines, bullet proof them! anybody agree or disagree with parts above?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-15-2011, 09:47 PM   #10
Hazieview
Re: 400 help
Why would u not reuse the stock crank and rods if they are still in good shape?
SB400 350th
Old 08-15-2011, 10:28 PM   #11
85Bowtie
85Bowtie's Avatar
Re: 400 help
You never bore an engine anymore than you need to clean up the cylinders. The steam holes somebody mentioned I believe you drill because the 400 is a siamese bore if I remember correctly.
I'm not sure what parts will get you 550HP the "easiest" on a "budget"....but I will tell you 550HP is a PITA for a vehicle you plan on driving often, especially in a place like LA. I make trips to Edwards AFB often, and I would never drive anything like that on the 405...
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 08-15-2011, 11:42 PM   #12
INSIDIOUS '86
Re: 400 help
400 is a siamese bore and i wouldnt even bore a 400 over .30 overbore since the walls get to thin for high hp.
and getting 500 hp is just a pita in general cause its a whole fiffrent ball game, alot has to change to make it rather reliable, and its even more pita to make it streetable at those levels
and to answer why i wouldnt reuse the stock crank and rods is that i just dont trust stockers past 400 hp to be reliable and a cast crank from scat is as cheap as refurbishing a used one just about, plus its lighter and you may as well get a matched and balanced rotating assembly instead of mix and match, just how i like to do things anyway, but for a 450 hp stock rotators and hyperutectic pistons do the job just fine
Old 08-16-2011, 02:39 PM   #13
406 Q-ship
406 Q-ship's Avatar
Re: 400 help
Ok this thread needs alot of clean up. I have a 406 SBC in my 71 Monte Carlo that puts 425 hp / 480 ft lbs with GM iron heads.
The block already has the steam holes that everyone speaks of, it is the heads that will need the steam holes drilled (unless you use heads off the 400). The stock crank is fine for up to 500 hp but edgy at that (450 better), the rods in a stock 400 are shorter than all the other SBC which is harder on the bores. If you choose to use the stock cast crank you will have to use external balanced flywheel/flexplate and harmonic balancer. DO NOT go over .030 over bore either, cylinder walls in a 400 are thin enough.
How do you want to use this engine, will it be a weekend warrior down at the local strip, will it be in a 4x4 that gets to go rockcrawling, or is going to take you back and forth to work everyday and must run on street gas?
I would not go above 10.00 on the compression if your going on a street gas engine, and at that high it will need good aluminum heads (9.0 with iron heads), on a race engine that may see the street go up to 11.0 compression. Cast bottom end is OK for a street driver that see track time but do NOT try to put a big cam in it, or try spining the engine to the moon. Use the 400's torque to your advantage, ignore all the Horsepower talk. Horsepower is a formula on a piece of paper, if you build it for torque, horsepower will take care of itself.
Here is the question to ask yourself:
1. What do I want to do with this engine in the truck? Daily Driver, weekend warrior, show truck?
2. Will it run on pump gas?
3. 2wd or 4x4?
4. Automatic or manual trans? If auto what converter and how much stall speed to live with?
5. What gear ratio?
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-16-2011, 05:44 PM   #14
Tony@AirRideTech
Junior Member
Re: 400 help
yup.... if it were mine....
350 crank.... good heads.... descent cam around a 510 lift with a standard trans and let her eat Also... personally I wouldnt go more than 30 over with the bore.
Tony@AirRideTech is offline   Reply With Quote
Old 08-16-2011, 07:02 PM   #15
406 Q-ship
406 Q-ship's Avatar
Re: 400 help
I actually agree with the 3.48 storke and spacer bearing in the 400 block, or get a 3.48 stroke crank in 400 main bearing sizes. With .030 overbore you get a 377, it has torque like a 350 but with a RPM range like a 327....oh my GOD what fun a 377 is! I have a fitting 400 block that I plan on making into a 372 (stardard bore 400) but I will not use it in my truck but in a nice road racer.
Old 08-16-2011, 07:10 PM   #16
3r!c84
Badass
3r!c84's Avatar
Re: 400 help
you dont need all that to go fast. i mean how fast do you want to go? just a weekend toy to take to the strip? this is what i got in mine..
400 small block. two eyebrow flat top pistons standerd bore 9:5to1compression . elgin cam split lift .503 .510 and split duration. stock truck heads.with bigger valves 1.5/1.9inch, 1:6roller rockers. edelbrock eps intake. holley 750 carb. msd ignition box. billet hei. stock th350 with a trans go shift kit. stock stall converter. 10bolt with 3:42 gears and airborne race posi. 235/75/15 tires.
and the video tells the rest..
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-16-2011, 08:09 PM   #17
87Bob
Re: 400 help
If I had a solid 400 block I'd build it. But these days if you want great power with out having to build a motor the LS series motors make great power. With more and more winding up in junk yards you can get a iron block for several hundred and not have to build it. One of the shows on the Spike Power Block did a transplant. Just get a low mileage one. It will have much more potential the the old small blocks. There are lots of performance parts available. Better fuel economy as well. True story: A friend of mine has a 92 Corvette LT1 with a blower from Lingenfelter, I have a 99 Corvette with a bone stock LS1 We are equal from a rolling 35 mph start. His blower cost 5,000 extra. Good luck with your build remember you have options.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 08-17-2011, 03:20 AM   #18
BigBlocksRule
Re: 400 help
Use a stock crank, they're nodular iron (just like big block cast cranks) and are generally good for more power than the stock block can take.
No real reason to destroke one, you're costing yourself power. Torque comes from displacement, more cubes = more power.
Find some Vortec heads, drill 'em for steam holes, get some pistons that'll put you at no more than 9.75:1 and build it. You'll have big block torque and small block economy.
BigBlocksRule is offline   Reply With Quote
Old 08-17-2011, 11:54 AM   #19
bmchevy1979
bmchevy1979's Avatar
Re: 400 help
I actually agree with the above about using a stock crank I have this exact decision to make right now I have a 400sb out of my blazer that has a shot crank and a good 350 crank and rods that I could put in with some spacers and new pistons or buy a used crank and hope it is not in the same shape as my current one or even buy a whole new crank I am still undecided but if you can I would go with the stock stroke crank
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 08-17-2011, 12:45 PM   #20
406 Q-ship
406 Q-ship's Avatar
Re: 400 help
No matter what you choose to do, use the longer rods from the 350 Chevy. The 5.7"(the lenght of the rod not the engine size) from a 350 will reduce friction in the engine along with more power the engine will last longer. The rods from any 1969 and later 307/305/350 are forged (except the really late 305/350 that had powdered metal ones) and more good for a hard running 406 SBC. My 406 has regular old GM 5.70" SBC rods. They will require a bit of clearancing if the base circle on the cam gets too big (mine has had this done).
Old 08-17-2011, 06:36 PM   #21
jrcaprai
Re: 400 help
1st thing to do, is make sure you get the block Sonic Checked to make sure you have enough cylinder wall to Bore...
Remember this, by the time you get your Crank And Rods Refurbed, you will be close in cost as a new Crank And Rods
Mine is a 408... .40 over.. I bought a Scat Forged Kit, 4340 Crank, Flat top Pistons, And 6.0 Inch Forged I beam Rods... It is Internally Balanced...
DON"T Destroke it... you will lose about 30-40 Ft-LBS of Torque and Horsepower...
The Heads, and Valve train are what limits your RPM's Not your Stroke.... Mine goes to 7000 RPM
You Want Big Power, #1 Priority is Good Heads... then Valvetrain... But make sure you have a solid Bottome end to support it.
I have 11.6 to 1 Compression, use Pump Gas and Drive on the Street...
My Cam is a Comp Roller 242/248 Dur @.50 and 576/600 Lift...
I have a 3000 RPM Converter, and it is very street-able...
Don't let these guys scare you into a torqey engine that falls off at 5000 RPM...
theres nothing like having a truck that screams to 7000 RPM before it falls off, and has just as much if not more torque than the 5000 RPM motor
Unless you're only going to Tow or Haul stuff with it
jrcaprai is offline   Reply With Quote
Old 08-18-2011, 11:52 AM   #22
406 Q-ship
406 Q-ship's Avatar
Re: 400 help
Mostly true but understand this too, a high RPM engine wears itself out faster, is more expensive to build because it requires better valvetrain and bottom end componants to stay together with the heavier 3.75 stroke To get the RPM to 7000 with a 3.75 stroke will require a cam that does not come on till at least 3000 RPM, and at that your throwing away alot of the reason for 400 SBC in the first place. That big of a cam will require a bigger stall converter, deeper gears, and low engine vacuum (think no boost on the power brakes), all of these things will get you a real gas using engine that is not fun on a daily driver, I am not trying to offend just give all the realitys. Do yourself and your wallet a favor, keep the RPM down to 6000 and under. My 406 pulls right up to 5500 and is the most fun you can have with your clothes on. Besides I run a stock L88 torque converter (2200 stall) and 3.31 gears and it runs down the highway without turning 3500 to go 65 mph.
Old 08-18-2011, 04:17 PM   #23
Silverray76
Re: 400 help
All of the advice is helping guys.
This truck is my daily i drive no more than 4 miles to work and only 12 round trip to school. Its a 2x4. I'm deciding to do this because im rebuilding the entire truck all over again and i would like more hp out of a new motor. I would like for my truck to run at least a 12 sec and i was planning to go out and find a rear end with 373 gears and posi. I want to keep it a auto and i belive my tranny has a B&M 2100 stall convertor and i plan to run pump gas
Old 08-18-2011, 07:19 PM   #24
3r!c84
Badass
3r!c84's Avatar
Re: 400 help
High hopes.. What's the price range on the motor build.
-00 Saturn 5spd
1/4:13:90
Old 08-18-2011, 09:52 PM   #25
tashspop
Re: 400 help
yeah, looks like until you give a price range, comments will be all overr the place.
tashspop is offline   Reply With Quote
