starter problem/question
Hey guys I just finished putting a used 70s(i think) Chevy 350 goodwrench motor in my 68 Chevy in place of the I6, the problem I'm having now now is the starter, its making a weird noise so I wanna change it cuz its the old I6 starter and I was told I could use it if I have a 168 tooth fly wheel witch I do, the truck has a 4speed m/t the ppl at the auto part store keep telling me I need to bring the old starter for the the 350, but I don't have it just the one thas on there now from the I6. Does the I6 starter have to be shimmed out?
#2 | |
Re: starter problem/question
Active Member
![]() Join Date: Jul 2007
In my case, I've never had to shim the starter in the few swaps I've done and starters that I've replaced so be sure and check the starter drive gear and/or flywheel teeth for abnormal wear.
If you do require shimming, there's a "faq" somewhere on how to do it and other related problems. I think this may help. http://67-72chevytrucks.com/vboard/s...archid=2497741 |
