Old 08-15-2011, 03:38 PM   #1
72GMC51
72GMC51
72GMC51's Avatar
Re: Fuel tank venting
So now that we have settled the question of the guy who jacked my post does anyone have an opinion on my original question?
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10.
Are they ever really finished
72GMC51 is offline   Reply With Quote
Old 08-15-2011, 05:22 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Sorry buddy, you're right, we got involved with the venting post to the extent we forgot to answer yours.
Anyway, yes, it is possible to force gas into the carb with too much pressure but worse, it could cause a leak into the engine oil pan to occur. In this hot weather the tank could create enough pressure to rupture the fuel pump diaphragm especially if it was aleady weak. As I mentioned in the other post, it could also lead to gas tank failure if the insides were already weakened from rust.
68gmsee is offline   Reply With Quote
Old 08-15-2011, 05:57 PM   #3
72GMC51
72GMC51
72GMC51's Avatar
Thank You, I thought that it could happen but wasn't sure I seem to have a very rich condition and have had the carb rebuilt and still is the same, I also had the diaphragm in my fuel pump go bad. I moved the tank to the rear of the truck and went through the work of installing the canister venting and all of the lines, so I will go back to using the system. I would just use a vented cap but the way I had the filler door done it is very difficult to get a cap on and off so I went with the push access. I have a cover so the lines and filler neck are not exposed just have not installed it yet.
Thanks Again
JC
