Old 08-12-2011, 03:44 PM   #1
jjcarron
false door window track removal?
hey all, I am stripping my burb down and just ha ve to remove the fasle door window track and stationary glass. Prob is, i cannot seem to get it out. i have tried everything I can without damaging the piece. If anyone has a good tip, it would be appreciated as this is the last thing i have to remove before lifting the tub off the frame.
thanks
Jeff
jjcarron is offline   Reply With Quote
Old 08-12-2011, 06:48 PM   #2
k5kev
New Member
Re: false door window track removal?
The track is held in with 2 screws at the bottom and one screw at the top going thru the header. With those out, the track should come out.
The stationary window can be a real tight fit . I just cut away at the weatherstripping with a razor knife to free it up, and eventually got it out along with the weatherstripping.
Good luck
k5kev is offline   Reply With Quote
Old 08-15-2011, 06:43 PM   #3
jjcarron
hey, ya, i cant find the top screw. looks like there is a molding that goes from the top of the window track, across to the front of the door and back down. i took the screws out all along this molding, but cannot for the life of me get it out. is the top screw behind this molding?
Old 08-16-2011, 03:53 PM   #4
jbclassix
Junk Yartist
jbclassix's Avatar
Do you have the front window track removed too? Once that is removed then the "molding" should come out easier and then you can get to the screw up in the top to remove the rear window track. I had to use HOT, soapy water to free the fixed window. I still chipped my glass
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-16-2011, 06:22 PM   #5
jjcarron
ya, i have the front track out. and have tried to get this molding out for a few hours. of course i am being extremely careful, cause im sure this piece would be hard to find. i guess i will just have to try for a little longer!!
thanks
