Old 08-14-2011, 09:29 PM   #26
Denee007
Denee007's Avatar
Re: Straight axle steering
Thanks, that's a great writeup and I've also watched on Orrrie's build thread of how he did this setup. Orrie has his own unique ways of making things work! I suppose the saginaw is a proven way for good power steering. I think when one's in the market, just need to weigh out all the choices and make the best choice for their needs. I'm torn between the 3 of these darned things! lol I'd like to see what mgbmike has to say about installing a crown vic front end, and that will probably make one of these 3 powersteering choices look very good! ; )
Originally Posted by Trucknut57 View Post
Denee007, Check out this link to see how the Saginaw PS is installed.
http://www.classicperform.com/power2.htm
Denee007 is offline   Reply With Quote
Old 08-14-2011, 10:01 PM   #27
Russell Ashley
Russell Ashley's Avatar
I'm using the Saginaw setup from CPP on my 57. I like it so far but it will limit your wheel and tire options. I have eight inch Corvette wheels with four inch back spacing and 235/75/15 tires. They don't rub but come within a quarter inch from touching the box when I turn completely to the right. I don't think I could run a larger tire.
Russell Ashley is offline   Reply With Quote
Old 08-15-2011, 01:35 PM   #28
mbgmike
Originally Posted by reinmeister1951 View Post
Mike a 55 car doesn't have a solid axle so mounting the rack to a solid crossmember is the way to go, but with an I beam axle the rack must move up and down with the axle or bump steer is inevitable.
Doug
Yeah I didn't think very much about it before posting. It would not work well at all. I am interested now on how well this setup works
mbgmike is offline   Reply With Quote
Old 08-15-2011, 02:32 PM   #29
mknittle
mknittle's Avatar
This is the main reason that I went with the mid 70s camaro firebird clip.also gives me lots of clearance for my big pontiac motors.also there is tons of after market parts for them!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-15-2011, 09:34 PM   #30
hsdropout
There is some interesting/positive feedback on the No Limit straight axle R&P kit on the Ford pickup forums (if you can stoop so low). Search: No Limit Rack & Pinion Kit-Report
I like it because it gets rid of all the old bs, arms, rods etc.
It's compact and the steering shaft comes up in a perfect location, clear for exhaust.
I have mono-leafs & disc brake kit. I have replaced wheel bearing and kingpins also.
It might not be the best option and I am not trying to sell it but it is interesting to me, I hope it works.
hsdropout is offline   Reply With Quote
