08-14-2011, 06:55 PM | #101 |
Re: 100's of misc parts from the last 6 trucks parted out
I have a 70 c20 Camper Special that my dad was the original owner of. I just retired from the Marine Corps and will be fixing it up (its actually still in very good condition). However I want to convert it to 4WD. I'm looking for a rolling frame or a donor vehicle. If you can point me in the right direction that would be great.
Dale |
08-15-2011, 06:06 PM | #102 |
Do you still have the "Blazer front top mount brackets 12.50" available? Also looking for a black steering wheel to fit a '71 Blazer.
Thanks. |
08-15-2011, 07:32 PM | #103 |
Do you have the rod between the brake pedal and power booster? I have everthing else I need to convert my 67 to power brakes, just missing the rod.
Thanks, Chris |
08-15-2011, 10:26 PM | #104 |
I'll take the 71-72 gas pedal w/cable 27.50. PM your paypal info. Thanks
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
08-16-2011, 01:54 AM | #105 |
"Junkyard Dog"
Lazzardknd, PM sent
Joe Blaze, yes on the mounts. No wheel at this time. Chris Bultman, sorry I only have the rod with a booster. nightmare, PM sent
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
08-16-2011, 02:14 PM | #106 |
The fuel filler cover arrived today. Just what I needed.
Thanks much. Roy |
08-17-2011, 08:15 PM | #107 |
We need to talk about some blazer parts sometime. I need the latch reinforcement plates for sure, and it looks like I just missed out on the fuel filler cover. You may have some other parts I'll be needing to finish my blazer. I'm at the racetrack every weekend.
1972 Chevy K5 Blazer 1972 Chevy K20 1955 Chevy 3100 "If we knew what it was we were doing, it would not be called research, would it?" - Albert Einstein |
08-17-2011, 08:27 PM | #108 |
I need the part of the window regulator the glass sits in, RH side.
(btw, i used to live in springfield!)
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
08-18-2011, 03:05 AM | #109 |
PIC #1 ASHTRAY - DARK GREEN IF YOU HAVE. How much to send to Califonia?
08-19-2011, 02:07 AM | #110 |
"Junkyard Dog"
rstrick, your welcome and Thanks
2fast55, PM sent webfoot, 15.00 plus shipping for the run channel. I was in Hermiston just last weekend! LMK Thanks Micks72, 17.50 shipped, thanks
08-19-2011, 11:36 AM | #111 |
Sounds good to me, please PM me know your payment info!
08-19-2011, 04:44 PM | #112 |
"Junkyard Dog"
08-19-2011, 05:04 PM | #113 |
08-19-2011, 06:30 PM | #114 |
hey im needing the underdash wiring and possily cab to bumper wiring as well does it matter if i have gauges ... is the one you have idiotlights.. if you still have it i'll take it thanks..
08-19-2011, 11:13 PM | #115 |
I'm interested in the following if they are still available:
-Black sunvisors -Inside mirror (not sure if any listed will fit my 68?) -Dome lens w/ chrome housing -Front and rear deluxe marker lenses (need set of four) -Backup lens (need two) -Tail lamp lens (need two) -Washer res. cap w/ hose -71-72 gas pedal w/ cable I didnt see them listed but I am also looking for the following: -Automatic shift position indicator (on top of steering column) -Heater controls (interested in almost anything, mine is totally destroyed) -67-68 park lamp lenses (the amber ones in the grill, need both) -the "T" in chevrolet on the hood -68 outside mirrors -brake and clutch pedal unit (and several other conversion parts if you have a donor available)
1968 C-10 Long Bed 307ci Automatic |
08-21-2011, 01:35 PM | #116 |
do you still have the "K5Blazer" emblems available?
I am also looking for this rubber piece that goes on the rear top of the driver's door: |
08-22-2011, 04:33 PM | #117 |
"Junkyard Dog"
I have the 68 dash wiring for gauges and the cab to bumper tail lamp harness. 90.00 plus shipping
08-22-2011, 04:41 PM | #118 |
Still Learning
tll74,
Any chance you can update the first post to reflect what is sold and still available? thanks |
08-22-2011, 05:15 PM | #119 |
Hi there, just waiting on payment info & shipping charge for the glass run channel to zip 97838.
08-22-2011, 08:34 PM | #120 |
yeah i'll take it man how do i go about buying it from you my zip is 37922
08-22-2011, 08:41 PM | #121 |
also my truck is a 69 with a 67 front end... how much diff is the 67,68 then 69-72
08-22-2011, 10:21 PM | #122 |
"Junkyard Dog"
Chewievette, PM sent
mcbassin, Yes I plan to later this evening. Thanks! Joe Blaze, PM sent and the K5 emblems are sold. webfoot, PM sent back. 68steppsidee, Yes they are different. I have the 69 wiring as well same cost. PM sent Guys, sorry for the delay been on vac over the weekend.
08-23-2011, 12:37 AM | #123 |
Still Learning
How much for the complete set of deluxe side markers shipped to 74851?
any fading on any of the lenses? thanks |
08-23-2011, 12:56 AM | #124 | |
"Junkyard Dog"
Thanks, Tom
08-23-2011, 08:29 AM | #125 |
Still Learning
Let me know.
