#351 |
Re: My 57 Pro Street
Well I got a little more done on the hood.
I'm using 3/8" steel rod for the runners. I made a jig to bend the runners that the hood will ride on. It's basically a bolt the same size as the roller with another to hold it in place. I heated it cherry red with a map gas torch and just bent it around the bolt. I also set up a jig for the other bends and did the same with them. Kim |
#352 |
A few more pics of the runners.
Kim |
#353 |
I've decided to use spherical rod ends for my tilt on the hood.
The first thing I had to do was come up with a way to attach them to the hood. Here's what I came up with. I used some 3/4x1/2 DOM and cut it to fit around my support rods. A couple of threaded inserts welded in and a home made gusset and it should work just fine. Kim |
#354 |
Here's a few more pics of them tacked in.
I just have to finish welding them and they'll be good to go. Kim |
#355 |
Kim57, Very nice job. I want to make one for my 48 panel when I get back to working on it. Thank you for great how to's.
Shannon |
#356 |
You....are awesome my man!!!!
Great work!!! I love looking at what you are going to be doing next....as always top notch work.
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
#357 |
always excellent work sir !
#358 |
Certified Car Nut
Looking good as always Kim. Great job.
#359 |
![]() Join Date: Mar 2011
Kim, looks real good....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#360 |
Thanks for the kind words guys. I do appreciate them.
Kim |
#361 |
Nice fab work,liked your rod bending jig.
#362 |
Incredible...can I ask what your background is? Engineer, fabricator, welder, all the above. Very gifted.
#363 |
Awesome work, keep it coming.
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#364 |
Again, a great mind at work. One thing to to look at, when bringing the hood foward from the closed position ,my rails did not have enough lift causing the corners of the hood to scrape the top of the fender. Also make sure you have enough roller depth on the rail and the rail straight because it can come off when rolling the hood back. When making this stuff it all trial and error, I can't wait to see it finished, then I'll have to redo mine.
#365 |
Kim you do some sweet work can't wait to see it finished.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
#366 | ||
Thanks.
I'm basically self taught at home. I've always liked tinkering with stuff since I was a little kid and been a hot rodder since before I could drive. I do wish I had the finances to get all the tools to make it easier but I get by jury rigging what I need. Thanks Quote:
If I have to redesign the rails it won't bother me that much as I don't have that much time or money in them. I was thinking I may need a rail on top of the roller but won't know until I get the hood mounted and give it a try. Thanks. I want to see it finished also but all things in time. Kim |
#367 |
I know how that is. I want to have my truck driveable by June next year not sure if it will happen. I don't want to rush through and cause more of a headache
#368 |
A320 Pilot/USAF Retired
Great work as always!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#369 |
![]() Join Date: Mar 2005
You are one crafty guy. I always look forward to updates on this thread.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#370 |
This is awesome fab work on your truck, I would rather make stuff that works than buy stuff that I have to re-work.
#371 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
Been looking at the bed........
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#372 |
These are the front brackets for connecting it to the cab. Kinda boring and tedious work but I had to get them done. I started with some 4" square tube and just went from there. Kim |
#373 |
Here's the rest of the pics on them.
I still need to clean up my welds but they seem like they should work OK. Kim |
#374 |
Dude, you are a fabricating fool! Awesome!!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#375 |
Looking good.....Jim
