Old 08-18-2011, 12:08 PM   #1
TigerDMD
Need HEI help
purchased a rebuilt HEI for my 68 from Langdons stovebolt - I was told it was a fairly easy install. I'm going to list the first 7 instructions and see if someone can dumb it down for me so that I can understand - I think im in over my head.
1. Rotate engine to No. 1 cylinder firing
2. Set slightly before T.D.C. approx 10 - 18 degrees B.T.D.C
3. Remove old distributor
4. install HEI and assure full oil pump drive tang engagement
5. Rotate distributor until 6 points on internal star wheel line up with 6 points on stationary pole piece
6. Note location of rotor and install #1 spark plug wire at this terminal. Install other wires in clockwise direction proceeding through firing order 1-5-3-6-2-4
7. Power feed must be a #10 size wire direct from ignition switch to coil + terminal. delete any resistor either ballast type or inline resistance wire.
I honestly don't know what any of that means. Thanks for the help.
TigerDMD is offline   Reply With Quote
Old 08-18-2011, 01:05 PM   #2
dmack91
dmack91's Avatar
Re: Need HEI help
OK, I will give it a shot.
1. Pull the distributor cap off of your stock dizzy and rotate the engine until the rotor is pointing where the terminal with the wire to cyl.#1 would be.
2. Check your timing mark. If you are between10-18 degrees TDC leave it, if past that, rotate back past 20, then slowly rotate the engine until between 18-10.
3. Just like it says.
4. Drop in the HEI. Make sure it goes all the way in as there is a shaft on the bottom that drives the oil pump. Generally, look at the old one, which should sit flush with the block when installed. Make sure the HEI is the same when installed (flush at the base where it meets the block - no gap).
5. Just as it says.
6. The rotor will be pointing at one of the plug wire attachment points on the cap when installed. This will be cyl. #1 now. Just wire the rest in the proper firing order, going clockwise.
7. Stock dizzy had a power wire with a resistor, either built in or possibly an external. This dropped the voltage going to the dizzy. The HEI needs full 12v, so you need to replace that wire with a 10 gauge wire without any type of resistor.
Good luck with the swap.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 08-18-2011, 01:45 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Need HEI help
With Dmacks help and this you should be ok.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-18-2011, 02:25 PM   #4
doodah man
doodah man's Avatar
Re: Need HEI help
I did this for the first time recently on my truck and was also a little intimidated. In fact, this was the first time I even had to set timing on an engine so everything was new. To make it just a little more exciting, I drove the truck 300 miles to the in-law's house for the weekend and did the swap there. The only major problem I had was that the HEI was a tooth off when I finally got it back together. The truck started but sounded awful. I pulled the HEI back out, advanced it a tooth, and drove home the next day. It's not nearly as hard as it seems from reading all the how-to's.
That said, here's some more reading material:
http://www.oldengine.org/unfaq/hei.htm
http://www.pontiacstreetperformance....onversion.html
http://rmcavoy.freeshell.org/HEI.html
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 08-18-2011, 06:11 PM   #5
FLDBRED
Re: Need HEI help
Year One sells a plug in type wire that makes it even easier! It goes from the box on your firewall right to the dist.,this way you don't have to "splice" anything,it plugs right in on both sides.
Like the others have said,with your batt. disconnected just find top dead center,by watching your timing mark,when it is just about on zero pull your dist. cap off and see if it is pointing to the No.1 plug wire.When you install your new dist.you should be real close.
FLDBRED is offline   Reply With Quote
Old 08-18-2011, 06:34 PM   #6
wilbilt
wilbilt's Avatar
Re: Need HEI help
Remember that the distributor is driven by the camshaft, which turns at half the crank speed. You want to make sure that when you line up the timing mark on the crank that the distributor rotor is pointed at the #1 plug wire and not #6. If it is pointed at #6, rotate the crank one more full turn to line the mark up again and this time the rotor will be pointed toward the #1 wire.
In theory, you could just reinstall the plug wires and "make" the #6 terminal become the new #1, but the lengths of the installed wires might not allow this.
And it is nice to remain consistent with the 5 million other Chevys on the planet on which the #1 terminal is at the front of the cap rather than back toward the firewall. It could save someone some confusion in the future. Just my 2¢.
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline   Reply With Quote
Old 08-18-2011, 06:40 PM   #7
webfoot
Re: Need HEI help
Helps to put the cap on and make a mark on the distributor body directly under the plug terminal you want as #1. That way when you stab your distributor you can see a little easier if the rotor is right on or a tooth off.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-18-2011, 08:01 PM   #8
johndawelder
johndawelder's Avatar
Re: Need HEI help
Remember, #1 piston coming up on the compression stroke.
johndawelder is offline   Reply With Quote
