Old 08-17-2011, 12:30 AM   #1
Eyegore
What Hump?
Eyegore's Avatar
Windshield Wiper moves when ignition is turned on HELP!!!
On my 1982 chevy 6.2 to warm up the glow plugs I have to turn the ignition on first to warm up the plugs, however when I do this rhe wipers make one swipe, it also happens when I turn on the headlights.
Any ideas on whats causing it to do this?
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 08-17-2011, 12:56 AM   #2
CHEVY_BOI93
Re: Windshield Wiper moves when ignition is turned on HELP!!!
this happened to me just last night. i was trying to re-wire the washer motor directly from the wind shield wiper motor. and every time i would start up my truck my wind shield wipers would turn on.
It turns out i had a bad ground cable hook up to a current so it was making them turn on automatically. if i were you i would go back and check ever wired you moved and or touched. i did this for about an hour trying to see what i did wrong. any little wire you hook up wrong will cause something else to work,
hope this works
CHEVY_BOI93 is offline   Reply With Quote
Old 08-17-2011, 05:21 PM   #3
Eyegore
What Hump?
Eyegore's Avatar
hope this works
Unfortuantly I never touched the wiring, was like this when it was purchased.
Lil red 86 c-10
99 Sub
Old 08-18-2011, 08:05 AM   #4
Desert1957
Desert1957's Avatar
Mt 83 just started this also , Can't wait to hear the fix.
(It has intermittent wipers if it makes a difference)
Desert
Desert1957 is offline   Reply With Quote
Old 08-18-2011, 08:51 AM   #5
sumran
sumran's Avatar
I haven't looked at the design on these trucks, but there is either a mechanical or electrical component that turns the wiper motor off when the blades are at the lowest position. Otherwise, the would stop in whatever position they were in when the switch was turned off. There must be a bad connection or defective component related to that. A bad ground makes sense.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 08-18-2011, 10:24 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
just fixed mine
my 78 switch pushed out the back
found a bent and broken copper strip inisde the switch
and it seemed fulla dirt,fixed it to work but no squirt
but the random swipes seem to be ground issues in later trucks
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-18-2011, 10:51 AM   #7
Eyegore
What Hump?
Eyegore's Avatar
motornut where do I begin to look for the grounding issue?
Lil red 86 c-10
99 Sub
Old 08-18-2011, 03:30 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
where the motors nuts are bolted in, on one it has a ground strap
what i've seen is the strip of copper strip may corrode or break
or the bolt rusts too
John
