Old 08-19-2011, 11:26 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
How low can i go?
So i was looking on the forums and one guy is saying that all his trucks had 6inch drop coils in the back without a notch......is this true how low can i go without a notch
ooimpalaoo is offline   Reply With Quote
Old 08-19-2011, 11:38 PM   #2
209jose71
Re: How low can i go?
it will hit on the frame that low i would rec doing a small c notch
209jose71 is offline   Reply With Quote
Old 08-20-2011, 12:42 AM   #3
SCOTI
SCOTI's Avatar
Some will hit, others won't.
You should be good up to 6" of drop for normal driving w/o any pay-load. Starting adding stuff in the bed area & get on a crappy road & it could possibly bottom out. There would be less chance of that happening w/the 5" rear drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-20-2011, 12:51 AM   #4
ooimpalaoo
ooimpalaoo's Avatar
and how low would i want to go in the front? with a 6 in the rear?
Old 08-20-2011, 12:53 AM   #5
SCOTI
SCOTI's Avatar
The industry 'standard' is a 2" difference from front to rear from the factory (rear end is higher to compensate for loading the trucks bed w/crap). So if you're looking for a 6" rear drop, you'll want a 4" front drop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-20-2011, 12:58 AM   #6
ooimpalaoo
ooimpalaoo's Avatar
thanx
Old 08-20-2011, 02:37 PM   #7
CPPJEFF
Best way to go is anything after 4 inch c-notch the frame, although you can remove the stock bumptop and go to a pancake bumpstop instad but i really suggest notching after 4 inches.
CPPJEFF is offline   Reply With Quote
