Closed Thread
Old 08-20-2011, 03:53 PM   #3676
pdxhall
pdxhall's Avatar
Re: What did you do to your truck today?
Got a visit from the Brown truck yesterday. New fuel tank and u-bolts and poly bushing for the trailing arms. Starting to fab up the fuel tank install. Hopefully I'll have pics tonight.
pdxhall is offline
Old 08-20-2011, 06:23 PM   #3677
towersddg9
towersddg9's Avatar
Put my dual fan in, plus a trinary for the ac clutch and 2nd fan
towersddg9 is offline
Old 08-20-2011, 09:35 PM   #3678
dodgiesdad
dodgiesdad's Avatar
Went to the range. My son and i shot his new rifle in and i re-sighted my muzzleloader in with a new scope.
dodgiesdad is offline
Old 08-20-2011, 09:49 PM   #3679
BMERDOC
BMERDOC's Avatar
Almost done painting it!!Gotta lower it soon!!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline
Old 08-20-2011, 10:28 PM   #3680
chevyrestoguy
chevyrestoguy's Avatar
I pulled the original 4-speed out of the truck and removed the crossmember in anticipation of the upcoming suspension swap. I also cut out the old exhaust and removed about 10lbs of dirt and grime off the chassis. I'll break out the steam cleaner next weekend and really make a mess.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline
Old 08-20-2011, 10:58 PM   #3681
pdxhall
pdxhall's Avatar
I started installing my new rear mount fuel tank. I'm not quite done yet but enough to post a couple of pix. What do you think?
pdxhall is offline
Old 08-20-2011, 11:34 PM   #3682
losthope
losthope's Avatar
well yesterday the neighbor kid needed some money to go to the high school football game, so i had him chase tools and had him crawl under the truck with me and i showed him how to install the th350 i picked up.He seemed really interested and it helped me since im still on crutches...then today i rewired engine compartment and hooked up a set of headman headers, and put the edelbrock carb that came with the truck on,and got the motor to turn over and a couple backfires through the carb ,but carb needs to be rebuilt and was leaking all over the place, so i moved on to putting some 6x9's in the gapping door holes and installed a cd player .....i now have tunes!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 08-21-2011, 01:29 AM   #3683
Rich 5150 69
Rich 5150 69's Avatar
Good to here you making progress, Losthope. did you here the news in our area, some guy working on his `54 chevy pu with a drop light had a fuel leak, set his garage on fire, lost his truck, `54 belair and mini van...sad
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 08-21-2011, 01:40 AM   #3684
losthope
losthope's Avatar
no i didnt hear that!!!!! what a shame!!everybody worrys about gas tanks in the cabs then others worry about them behind the axle sometimes its the things you dont expect that go wrong....
Timmy D.
losthope is offline
Old 08-21-2011, 02:01 AM   #3685
samuellg1977
samuellg1977's Avatar
I added some length to my exhaust. The duals dumped right behind the cab and echoed on EVERYTHING under the bed. Now, nice and quiet in the cab with a little bit of rumble outside... the way it should be. Now, maybe I won't get headaches from the roaring in the cab with me!!
samuellg1977 is offline
Old 08-21-2011, 02:46 AM   #3686
Slow Build
Slow Build's Avatar
How far back did you go with the exhaust.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 08-21-2011, 04:01 AM   #3687
samuellg1977
The end of the muffler is in the center of the cab, but the pipe runs all the way out to the step on each side. Considering putting a X or H-pipe in it to balance it out. I dunno yet though.
Old 08-21-2011, 09:20 AM   #3688
Rich 5150 69
Looks good pdxhall, Mustang...? how many gallons....? How much room for the tracking bar...?
Old 08-21-2011, 11:17 AM   #3689
samuellg1977
Here is a picture of the mufflers and the drivers side extension i put on yesterday. Makes a world of difference inside the cab.
Old 08-21-2011, 11:40 AM   #3690
HEI451
You might also add a balance tube in the after muffler tubing between both pipes, near where the exit the mufflers.
HEI451 is offline
Old 08-21-2011, 12:10 PM   #3691
samuellg1977
In addition to or in place of an H-pipe before the mufflers? What does this do to the performance or sound? It is an all stock 350 with some headers, so I am not concerned with peeling the street back or anything. I just like a nice V8 sound out of these old trucks.
Old 08-21-2011, 12:56 PM   #3692
HEI451
I would have built an X pipe instead of a front balance tube, and then, add the rear balance tube to the after muffler/tail pipe setup.
This does help overall performance, and helps keep the system quieter, without making it sound like a Rolls Royce.
I am building this system for my 1964 Chevy C30 1 ton dually flatbed truck, with 305E V6. Have same on my 1972 all aluminum Rover V8 engined Vega.
HEI451 is offline
Old 08-21-2011, 03:43 PM   #3693
Vernski
Originally Posted by el_bole View Post
Mark,
What are the tail lights you are running on your GMC? I just got a short bed and looking at options for the tail lights....dont really care for the original look..
Thanks,
Roberto
Hey Roberto you could PM Mark about the taillights or look in the search under taillights I know he had a write up on the forums about them...Vernski
Vernski is offline
Old 08-21-2011, 06:50 PM   #3694
pdxhall
pdxhall's Avatar
X2
yes, it's an early mustang tank, 16 gal. It will not interfere with the track bar where I mounted it. The cross bars for the bed will have to be modified slightly but I really like the way in tucks into the frame with very little hanging down.
pdxhall is offline
Old 08-21-2011, 06:54 PM   #3695
markeb01
Senior Enthusiast
markeb01's Avatar
Mark,
Thanks,
Roberto
Hi Roberto, I didn’t see you post until I spotted Vernski’s reply this afternoon. The tail lights are aftermarket 1959 Cadillac, and the brackets were custom made by my son who’s a machinist.
I’ll pull together the component photos, install pictures and original drawings and try to get them posted later tonight. Thanks for asking, Mark.
markeb01 is offline
Old 08-21-2011, 07:18 PM   #3696
el_bole
Vernski and Mark,
Thanks for getting back to me LOL. By the way vernski love the stance on your GMC, did you use drop spindles too or just the springs?
Thanks for the info Mark, I look forward to seeing the write up about the caddy tail lights...
Well I worked and sweated all day disconnecting everything from my '61's 235 inline six, gonna remove it.....
On a seperate note I bought a c10 2wd SB rolling chassis for the axle/cross members and I am considering puttin my '61 cab and bed on it. Any thoughts?
Captainfab gave me some great insights, I'd just like more opinions.. Thanks guys for helping a guy out.
Roberto
el_bole is offline
Old 08-21-2011, 10:12 PM   #3697
Vernski
Vernski and Mark,
Roberto
Just the coil springs Roberto it still has stock spindles but because it's GMC it has leaf springs on the rear w/3 leafs taken out...Verski
Vernski is offline
Old 08-21-2011, 10:14 PM   #3698
smilts60
I went out in the backyard today, and took a real good long hard look at my truck. Then went to bed. But a couple of days back I cleaned out he back. and removed the seats did some fiddling with the tailgate. Im getting ready to move it around front and begin work on it.
smilts60 is offline
Old 08-21-2011, 11:24 PM   #3699
bobbylast
bobbylast's Avatar
i found a six foot long batch of shed snake skin... today i sprayed my truck out with spectracide...hopefully any lurking snakes will bail out.
If you used to be...then i guess you never were.
bobbylast is offline
Old 08-21-2011, 11:59 PM   #3700
samuellg1977
It's not that I am afraid of snakes... It's a game that I play... When I see a snake, I scream like a little girl and RUN. The farther away I get, the more points I award myself. And I have NEVER lost!!!
Closed Thread
