![]() Join Date: Jun 2008
lifted 92 rcsb part out
i am parting out a 92 reg cab stepside the truck fell into a ditch and the pass side of the truck got messed up pretty bad when it was pulled out. i bought it for the engine and trans and am parting the rest out.
6in suspension lift 600.00 3in body lift 75.00 Red high back bucket seats and console 150.00 6 lug G80 Rear 75.00 Hood with two ram air scoops 40.00 15"x10" wheels 150.00 Automatic steering column 85.00 ![]() ![]() ![]() ![]() Last edited by crazyredneck; 08-19-2011 at 09:46 PM. |
"GO DAWGS"
Re: lifted 92 rcsb part out
Are those truck buckets and console or are they suburban/tahoe seats and console. The reg cab truck console does not have the slide out tray in the back and the seat tracks are different on the suburban than the trucks.
Thanks PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
the seats are out of a reg cab truck but the console was taken out of a suburban the original one from the truck was trashed
Posted via Mobile Device |
Are the scoops on the hood the stick on ones?? Would you be willing to sell just the scoops if so. and how much?
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
what kinda of lift is it????
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
The scoops are the stick on kind but the guy cut the front of the scoops out i guess so they'd be functional and he also cut the hood id like to get 40 for them just because the hood is worthless without them being cut out for them
On the lift i belive it is an older BDS set up im not 100% sure on it. I havent seen any markings on it, its the style that has the drop brackets for the upper control arm not the lift spindle or ball joint spacers. |
does it relocate the front diff lower?
Well I kinda figured you'd want to leave them on the hood, but it doesn't hurt to ask. Thanks for replying. But I'll pass on the scoops, and hood.
yes it does relocate the front diff lower
Chris
what all would be included with the body lift? looks like for sure it has the front bumper bracket to raise it, kinda looks like the rear is too? but then you got 2-4 metal blocks that are hollow under the bed to support it from sagging, not the actual lift blocks that are nylon or whatever but metal ones if they were used, a filler neck extension, t-case linkage extension maybe? trans linkage usually has one, and then a steering extension and something for the front fan shroud?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
if you were close enough I would buy the whole truck and build it. I got two of every body panel to put it back together.
on the body lift id have to look at it closer but i would include everything that goes with it i know for sure that the pieces for the fan shroud are missing and the rear bumper brackets got messed up in the accident
Chris
I may be able to straighten up the rears, if not I can use em for something, modify to work or whatever.
I'll take the buckets and console if still available. Please advise
#15 |
how much for the white visor above the windshield shipped to 37745? Thank you
#16 |
Your truck is nice, as per my view you can easily sale your truck to Transportation Company’s owner, he will modify your truck and use for moving and transportation.
#17 |
#18 |
Chris
I'm still interested in the body lift also.
#19 |
sorry guys my computer went down everything besides the lift sold locally on craigslist sorry again about the down time
#20 |
Chris
which lift the body lift or the frame lift?
#21 |
Got a tape unit w/ equalizer?
