Old 08-07-2003, 08:10 AM   #1
gjl327
Suburban tailgate won't open
I have an 89 with the usual inoperable tailgate.
Window works (barely)
tailgate has it's inner panel on
Short of an angle grinder, how do I go about opening this sucker up?
Thanks for any info
Gerald
gjl327 is offline   Reply With Quote
Old 08-07-2003, 09:30 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
My Jimmy tailgate was stuck closed also. I climbed in it and took the access panel off and pulled the rods. I then adjusted them so they would work.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-08-2003, 10:26 PM   #3
Grim Reaper
I know K5's are very prone to having the bottom of the window tracks rust off. This allows the window to be in the wrong possition. Now I haven't open up that new of gate but on my 79 K5 there is a safety lock out that keeps you from opening the gate unless the window is fully open. If the bottom of the tracks rust off then it misses that device.
If it's like my 79 K5 then pull the inside pannel and in the middle will be a L bracket on a slide that the window hits when all the way open. It releases a mechanisim up by the handle to let you open it. I also had a spring break on that thing and it screwed up then as well.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-08-2003, 11:37 PM   #4
gjl327
I thought the inner panel couldn't be removed in the closed position
Is that so or is it just a PITA
Gerald
Old 08-09-2003, 12:09 AM   #5
Grim Reaper
Gerald
Hmmm well my 79 didn't have the dressy carpeted cover just the inner steel pannel and that's no problem to get off.
I havne't had a reason to mess with the 88 burb so I honestly don't know if you pop off the carpet peice with it closed. I would think you could. It seals at the steel of the door so the pannel should be smaller then the opening.
Grim-Reaper
Old 08-09-2003, 07:31 PM   #6
gjl327
Thanks for the help
I managed to get the carpet off quite easily. forced the door open, found that one latch was seized. a little work with WD40 and a hammer and it was fixed.
I also cleaned all the gears and sliders for the window, but in the end it did not help. I think the guides are toast. Oh well
Door fixed..Thanks again
Gerald
