RAT1968 '68 Cab/'71 Parts
I Did Something Stupid- Again
I pulled two cabs apart putting the Rat together and I forgot to take pics of the routing and connections (hoses) for the windshield "washer".
Monday morning I'm going to get after it, and I'd like to save a trip to the shop since I'm going for some parts tomorrow. Anyone have hose routing pics and/or amount and size of hose needed for this little chore? In the engine compartment? At the pump? Thanks much.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Old Skool Club
![]() Join Date: Jun 2001
Re: I Did Something Stupid- Again
Aren't there three hose connections on the washer pump? One for each nozzle and one from the reservoir to the pump. Only the supply side runs through the bulkhead/firewall. The others are in the plenum, under the plenum cover.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Okay. From the supply up on the drivers inner side of the fender next to the rad core support.
Then the supply line goes thru the firewall at that grommet with three holes in it? To the "pump"? If I had the pump here (it's bolted under the dash), would it be obvious which connector the hose would slip on? Then, the other two "nipples" (for lack of a better word) on the pump route some way to the windshield nozzles? But not thru the fire wall, huh? Thanks a bunch for the help.
My hoses from the pump run back out through the firewall (in the 3-hole grommet) and then run trough the wiring gutter on the firewall to the point they go back through the firewall via a 1-hole grommet to the nozzles located under the cowl grille.
Easy to see, hard to explain LOL
1971 GMC C2500 Custom Camper - Second Owner. 350/TH350, Dana 60 Rear. |
Dont know if this will help much, but i have a pic
