2005 trailblazer a/c?
I have a 2005 trailblazer and the a/c doesn't work at an idle. I checked the pressures and the low side was 45psi and the high side was 175psi. I thought maybe the compressor was bad so I bought a reman and put it on today. I did a half hour vacuum and then tried to charge it. It wouldn't really suck the freon in very well. I got 2lbs in it (takes 2.8lbs) and the compressor started locking up? The pressures were 45psi and 200psi. The low side still won't come down. I am at a loss now and hoping someone else has some advice. I don't want to pay the dealership to fix this but I might have to.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
Re: 2005 trailblazer a/c?
I might have found an answer. After searching the web I found out that gm has a service letter out for 2005 and older TB's. Apparently at idle the engine fan doesn't engage enough to cool the condenser causing the a/c to not work. I feel like a dip $*#! for not thinking about the fan causing this problem in the first place since it all makes sense now. Oh well live and learn I guess. Hope this helps someone else.
Thanks! I really haven't had a problem with the '03, but now I'll keep this in mind.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
![]() Join Date: Sep 2005
had that problem yesterday int he shop on a benz ml320 low side was 75psi and high side was pegging 520psi it was in a wreck and the fuse for the fan had blown installed a new fuse and evacuated and recharege the ac was good as new
