Old 08-22-2011, 05:01 PM   #1
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Rear wheels moving in & out.
Had new rear tires fitted on my Truck today, the guy calls me over, and showed me when he pulled IN and OUT on the tire he got about 1/4 inch of movement. It made a real obvious clunk in & clunk out....he asked if I'd noticed anything while driving it, I told him the truck does feel like it shifts slightly at the rear on corners...so this must be why, so can I just tighten the nuts on the end of the axles to eliminate this? or is this a deeper issue?
Thanks.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 08-22-2011, 05:14 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Rear wheels moving in & out.
when was the last time the wheel bearings were repack grease ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-22-2011, 06:11 PM   #3
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
The rear axles are held in by C-clips on the inside of the diff. housing. It is normal to have a little in and out movement. I wouldn't worry.
Joe
DREAMS OF A 67 is offline   Reply With Quote
Old 08-22-2011, 06:11 PM   #4
eightbanger
454 MAKES IT ROAR
Not in the 3 yrs I 've owned the truck, god only knows when before that...how easy or difficult a job is it to repack with grease?
Nigel.
No more pain.
Old 08-22-2011, 06:14 PM   #5
fastwillie 696969
~Rest In Peace~
my bad its rear wheels i was thinking fronts ,repack wheel bearings on the rear i should be shot
Old 08-22-2011, 06:55 PM   #6
eightbanger
454 MAKES IT ROAR
Joe, how much movement would be normal? it was clunking in & out
No biggy mate thanks for trying to help.
Nigel.
No more pain.
Old 08-22-2011, 07:10 PM   #7
68gmsee
Active Member
68gmsee's Avatar
If you can feel the rear end shifting or making noise when you drive around, then it's probably something you may want to check. A small amount of play is okay but if you feel uncomfortable with it then you're going worry until you check it so you may as well do it.
It's easy enough to pull the rear cover. And, while you have it off clean it, check the c clips and replace the lube.
68gmsee is offline   Reply With Quote
Old 08-22-2011, 07:12 PM   #8
yuccales
yuccales's Avatar
You used to be able to get thicker c-clips from GM. Sure someone will chime in and let you know where to get them now.
yuccales is offline   Reply With Quote
Old 08-22-2011, 07:26 PM   #9
eightbanger
454 MAKES IT ROAR
It is worring me, had DS trouble a while back so had the cover off then and replaced the oil, if im honest there is a faint noise from the rear end & now this...my gut is telling me there's a rebuild comming.
I should have mentioned that it is a posi, not that that should make any difference.
Are the C clips easy to pull? I mean, is it like a complete tear down to get at em?
Nigel.
No more pain.
Old 08-22-2011, 07:58 PM   #10
DREAMS OF A 67
Step Brother
I would say no more than 1/4"
Joe
Old 08-22-2011, 08:02 PM   #11
Daves70
Daves70's Avatar
It could also be your track bar bushings. Have someone "ROCK" the truck side to side and see if there is play in the bushings on the end of the track bar.If there is replace the bushings.Real cheap and easy.
Daves70 is offline   Reply With Quote
Old 08-22-2011, 08:07 PM   #12
DREAMS OF A 67
Step Brother
or trailing arm bushings.
Joe
Old 08-22-2011, 08:27 PM   #13
tcb-1
Nothing to see here.....
tcb-1's Avatar
Nigel,
Check those c clips mate!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-22-2011, 09:06 PM   #14
LONGHAIR
There should be some movement there, but a quater inch is quite a bit. It is possible that the C-clips, axle ends, nd/or center pin all have some wear on them. All of it adding up to excessive movement. I would pull the cover off and have a look. It needs new lube anyway, the inside of the differential is one of the most ignored things on any car/truck.
BTW, there are rear ends with adjustable (tapered) wheel bearings, just not on half ton trucks. They are full-floater style.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-22-2011, 09:12 PM   #15
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would check this first.You can check just by getting under the truck and seeing how much play is in the "Panhard" or track bar.
This is a case of "When you hear hoofbeats,it's highly unlikely that you will find a Unicorn". Meaning check the most obvious (orsimplest) ones first.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
