Center Link hits Engine Cross Member
Ugh. I am having a tough evening. I thought I had everything ready to go, but then my Tie Rod End was hitting my wheel so i took a second look at it all. Then I realized the inner TRE was mounted upside down. Simple fix, right?
Wrong. They only slip into the center link (is that the right term?) one direction. Which means unbolting idler arm, pitman arm and both TRE to flip it around. Great problem solved, except that it hits the cross member. What do I have wrong? As is my TREs are upside down and I can't slide the sway bar in correctly as the contact. If I flip them over they won't slip into the center link, and if I flip the center link end to end it contacts with the cross member.
www.tomthetruck.blogspot.com <-- Aka build thread. |
Suburban Hick
![]() Join Date: Aug 2008
Re: Center Link hits Engine Cross Member
I will tell you the same thing i tell my brother lol. When in doubt consult the lmc truck catalog for a exploded view of the part of the truck your working on. Heres a link to the page with steering components. Hope it helps.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=129
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
#3 | |
Suburban Hick
I may not buy many parts from them, but those catalogs are a lifesaver when you don't have another truck to look at.
Problem still exists, when I set it up as the images at LMC have it and as I thought it should be it still hits my cross member.
67-72 parts collector,…
![]() Join Date: Nov 2002
Got any pics?
That is the way that it will clear the cross member, but puts the TRE upside down as they won't thread through the top, only the bottom when the bend is towards the grill.
www.tomthetruck.blogspot.com <-- Aka build thread. Last edited by Tmwoodall; 08-22-2011 at 11:38 PM. Reason: Correction. |
Image one shows it setup how I believe is correct, with wheels full turn to the passenger side. Second shows it hitting the cross member and it is barely turned back towards driver side.
I think it goes without saying but my toe-in, steering center point, etc are not setup at this point. For now I am just trying to figure out what I have setup incorrectly.
I just looked at mine that I just put back together. Your Drivers side and pitman arm looks setup the same as mine. Mine gets close but does not hit. What does your idler arm setup look like, I think that may be where the problem is now.
Grandpa in the rustmobile...
Mine did the same thing when I swapped for discs.. i had something backwards or not right..i cant remember right off, something wasnt right or i still had the drum brake piece or something..
get more pics
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Passenger side/idler arm.
It was a disc truck stock. I should have taken more pictures when I tore it apart to use as a guide.....
Yours is set up exactly like I did mine, my close point looks like yours when it's turned to the passenger side. Did you buy a replacement pitman or idler that may be a little longer, everything is oriented properly from the pictures you have.
i'll crawl under mine in the AM i cant remember, msg lolife99 he'll know asap
#14 | |
The only other two variables I can think of are the shims at the top between the frame and the a arm shaft, but that shouldn't affect this. Lastly the front to back orientation of the u-bolts on the lower a-arm shaft. Perhaps I have it off? I tore this thing apart down to the very last item so everything including the cross member was pulled out. The A-arm lower shaft - Ubolt orientation is the only thing I can think of that makes sense, but even that doesn't seem like it would do it. When I set those I just centered it by measuring from the lip of the arm to the cross member and set them equidistant front to back.
#15 |
I pulled everything on mine apart except the cross member. The a-arms should have no effect on the center link to cross member spacing. The idler arm and steering box are pretty much fixed in their location, is the cross member able to move back at all? That is my only guess at this point is that the cross member is a little more forward than it was before. I know there is not much clearance so even 1/4" could cause a problem. Someone on mere must know more about this than I do.
#16 |
There is a hole to index the lower control arm shafts to the cross member. If you did not use that hole to index them they may be too far back. Even that should not affect the center link distance from the cross member. That distance it controlled by the idler and pitman arms.
Is it actually touching or is it just really close? Mine is within a 1/4" of the cross member.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 08-23-2011 at 09:52 AM. |
#17 |
That is what I am hoping it is, as that would push the steering knuckle out a bit. I'm skeptical that it will make that big of a difference, but it's the last thing I can think of I haven't checked/fixed already.
#18 |
I am a Referee of life.
Ok I may be able to help with this one.IIRC someone else had the same problem.The fix was to turn the center link over.They had it in backwards.I'm not sure this is yoiur problem but it's worth checking.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#19 |
Already tried that. The holes are tapered to only accept the TRE in one direction, same with the Pitman and Idler arms. To flip it over would put the TRE upsidedown.
#20 |
It looks like everything is oriented correctly. I think this problem will go away once you torque everything down and get it on the ground with all the weight on it.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#21 |
Suburban Hick
This is just a thought not sure if it will cause a problem, but what happens when you put weight on the front of the frame? You are missing about 800 pounds of stuff on that thing.
#22 |
Well, that leads me to a whole new problem. I sold the 20s that I bought years ago since they were bought with the taste of an adolescent young buck. The 15" rollers I bought on it are too small and contact the Tie Rod End. So until I buy some new wheels I won't know... I guess I could pop the tires under the A-Arms and stand on it and that would give it a good 230lb test.
#23 | |
#24 | |
Thanks guys. Looks like case closed on this one.
#25 |
Glad to hear it.
