![]() Join Date: Aug 2007
Best High Temp Coating for Cast Iron
I want to put a good finish on my rams head cast iron headers. I see brush-on, spray and a rub on dressing. I want it to hold up, what do you guys recommend?
![]() Robert 71 Chevy SWB |
![]() Join Date: Apr 2008
Re: Best High Temp Coating for Cast Iron
I will be interested in the replies because I want to do the same thing.
Eastwood had a high temp powder coat that was specifically designed for exhaust manifolds and headers but had to hold off production because some shipping issues that affected the product performance, and I never got to try it while I was building my exhaust.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Junior Member
I have been pleased with results using eastwood's high temp exhaust manifold paint applied with a foam brush. Comes in a little can. I have used both the brighter silver and after it was available, the cast iron color. Best results were with freshly sand blasted manifolds and follow the instructions. I recall you are supposed to let it dry before you start the engine and bake it on. It can make a significant visual difference on rusty manifolds but the rust will eventually come thru applied that way. Applied to sandblasted manifolds per instructions the finish has lasted many years on my Sunday drivers.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
I bought some VHT hi-temp paint that is supposed to be good to 2000 degrees(we shall see) I have started the truck and let it idle and so far so good. I soaked my manifolds in vinegar for a week then rinsed and dried right before coating them.
![]() Join Date: Nov 2007
I used the eastwood cast-gray coating that you apply with the foam brush. I broke my motor in on it (pontiac 400 with ram air manifolds) and they looked good after. It goes on a little streaky. The VHT cast grey 2000 stuff looks very good but I haven't tried it on a manifold.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
Six in a row makes it go...
![]() Join Date: Mar 2009
I used the Eastwood brush-on stuff also. My buddy claimed he had good luck with it and the engine shop suggested it also. I haven't fired it up yet, so I don't know.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
I am a Referee of life.
Mine looks good.I pretty much followed the directions on the VHT can.I didn't blast but used a wire brush and cleaned thoroughly.It has held up well for the 2-3 months it's been on there.I did just the exhuast with it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Moderator
![]() Join Date: May 2007
I use POR 20 hi temp paint. Daily driven, has held up for over 4 years.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I've got some ram horn manifolds that I sandblsted and applied the Eastwood brush on coating. I've been running them for 20 years or so and they still look pretty good.
"Negative people always seem to have a problem for every solution" |
subscribed
Cruzin
i used easwood's brush on manifold paint on my 71 has held up pretty good and easy to re coat and just high temp grill paint on my wife's 67 (it hasn't been run but a couple hours so far)
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Fuzzy |
VA72C10
![]() Join Date: Mar 2008
were the manifolds blasted or rusty?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#15 |
Moderator
I cleaned them with a wire brush. POR 20 and POR 15 are different formulas. If you put regular POR 15 on an exhaust manifold, it will burn off.
#16 |
I used POR20 on mine. They recommend coating them right after sandblasting and thats what I did. The header on the right is bare metal after sandblasting. The header on the left is coated with POR20.
1971 C10 Cheyenne Super Build Thread Here: http://67-72chevytrucks.com/vboard/s...d.php?t=411867 |
