Old 08-24-2011, 05:28 PM   #251
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1966 SBBW pro street
I made some changes this week.....I realized that summer is almost over so i might as well slow down and get excatly what i want.....no need to rush it and then redo something later when i should be driving it. Keeping that in mind I hope to start body work in about 10 days....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 08-24-2011, 05:36 PM   #252
hotrod1
56 - autocross
hotrod1's Avatar
Thats nice!
hotrod1 is offline   Reply With Quote
Old 08-24-2011, 05:46 PM   #253
c.brown
c.brown's Avatar
nice work looking good !
1966 suburban slammed fuel injected 6.2L
My build
c.brown is offline   Reply With Quote
Old 08-24-2011, 06:44 PM   #254
wutnxt
Thanks guy's......it's always nice to get some feed back ...it's even better when it's good feedback....lol
Old 08-24-2011, 07:49 PM   #255
65Pickup
65Pickup's Avatar
Ok more kudos, great fabrication...your engine set back still blows my mind.
65Pickup is offline   Reply With Quote
Old 08-24-2011, 07:57 PM   #256
wutnxt
Wait till you see the cross member .....pulling the dummy block out in the next day or 2 and then the cross member will need to finished. The way it sits right now the bottom pulley is more then half way back on the cross member. It's going to be a differnt look when it's all done. I just hope I don't pound a hole in my oil pan when it's aired down...that would suck.
Old 08-24-2011, 08:19 PM   #257
65Pickup
65Pickup's Avatar
So much going on I keep forgetting that your bagged too...too cool. Did you make it to Spokane Goodguys?
Old 08-24-2011, 08:23 PM   #258
wutnxt
Nope...I ended up going to a couple of cruises local which worked out awesome...It's always nice when you first get them together that you get some time in close to home....lol...a nut here a screw there so to speak.
Old 08-25-2011, 03:19 PM   #259
Dinos63
chevy only
Dinos63's Avatar
holy shhh-- that floor is sweet thats a game changer , nice work kat!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-25-2011, 03:26 PM   #260
wutnxt
Dino
Thanks dude....I almost don't want to cover it up with carpet now....lol...Wonder what the floor would look like if i just spray'd the floor with bed liner....Naaaa guess i got to use carpet.
Old 08-25-2011, 04:01 PM   #261
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work, and I'm loving the long box! Yes, that fire wall is sweet! You're hauling butt on this build, keep it up!
Ryan
1969 Chevy milk truck
Old 08-25-2011, 04:23 PM   #262
wutnxt
Diesel..
Thanks man...I can't wait till it's finished.....I am getting tired of pulling wrench on so many differnt projects at once...lol..Speaking of which I see you have a 72 longhorn, I have one too but haven't touched it yet. I was going to make it into my tow vechile but i ended up going a differnt direction.
Old 08-25-2011, 09:59 PM   #263
chad64chevy
chad64chevy's Avatar
i have been waiting for the pictures! lol! that floor and firewall look great, and you blue truck is awesome! i like the blue and white it pops at ya! so how are you going to do your steering, brakes, and gas pedal with the new firewall and trans tunnel??
chad64chevy is offline   Reply With Quote
Old 08-25-2011, 10:20 PM   #264
wutnxt
Well those are good questions.....I haven't decided yet if the booster is going under the floor or on the firewall just yet....The problem is that if i put the booster under the truck...all of my big exhaust runs there and with the truck aired down a 1" off the ground there isn't much room. But wildwood makes a pedal master cylinder combo that could all fit inside the truck and up under the dash and i really don't need a booster with 4 wheels disk brakes.......So that i have to think about yet.The steering is going through the firewall and is a polished flamming river set up.....the gas pedal is a built in set up thats a easy fix.
Old 08-25-2011, 10:27 PM   #265
chad64chevy
thats cool i got lokar 55-57 brake pedal with the built in offset and there Lokar Eliminator Floor Mount Gas Pedal that goes thru the floor and has a braided cable! the cable will run up the firewall, and it should look nice!!
Old 08-25-2011, 10:30 PM   #266
wutnxt
Chad
That sounds alot like the gas pedal setup I am going to look at.....So many options....
Old 08-25-2011, 10:47 PM   #267
chad64chevy
i think it would work for you, you got mount it where ever you want to it has a 36" braided cable but can be cut down! i bought the stuff at the beginning of summer thinking i might have enough time to work on it this summer and have the cab ready for carpet and paint! the heat and having to many things going on kick my butt! tomorrow ill take some picture and post them for you so you can see!! i still havent done anything about my cowl hood! speaking of hoods, how is yours coming along?? have you done anything yet?
Old 08-25-2011, 10:59 PM   #268
wutnxt
I haven't done much with the hood just yet.....and until i get my final engine height....I don't want to start it and find out I need another 1" or something.......
Old 08-25-2011, 11:04 PM   #269
chad64chevy
well when you do get around to doing the hood take lots of pictures! so i can see how its done on our hoods and i can start on mine!
Old 08-25-2011, 11:07 PM   #270
wutnxt
I hope to have it at the body shop in about 10 days for "awhile"......after it's mostly done I will finish off the rest of my issues....lol
Old 08-26-2011, 01:35 AM   #271
Dieselwrencher
Originally Posted by wutnxt View Post
Diesel..
I hear you on too many projects. That's the story of my life! I do get tired of working on Dodges. Hopefully I can get the Longhorn rolling soon. Keep stabbing away, that's the only these long haul projects get done brother!
Ryan
Old 08-28-2011, 12:16 PM   #272
wutnxt
Well i guess the next challenges will be.....finding some junker wheels that are 33" tall for the rear and a set for up front. I just had all the wheels polished and new rubber put on and i know how the body shop rolls.....lol. I don't want all of that covered in primer and over spray. Then i guess I have to figure out how to block it up to ride height with out all the air ride in....
But here is a real big question for all of you, I was thinking originally of going a dark green with a pearl white. Then I was thinking that factory color the cab was in and in a satin, not a patina but in a satin. So i have to decide satin.....or gloss ? I think i am chicken to paint it in satin incase I don't like it and have to redo it. It's going to be painted in pieces and put together and then painted again, so it would be huge to change it.
well any ideas?
Old 08-28-2011, 01:50 PM   #273
65Pickup
65Pickup's Avatar
Guess I'll weigh in, I happen to love the sheen of satin, but make sure you use a satin clear as you'll start polishing the finish every time you rub it. The Harley guys use a product called Ace-It to detail the satin parts of their bikes and keep it from shining. Also applying the paint is quite difficult, as any flaws need a complete respray as the satin shows differently sheen wise when spotted. You can't sand and respray or polish a mark out. So I hear, no experience yet, just gathering info.
Color is very difficult, Dino is probably staying that light blue green color, but your at paint first. I really like that color on our trucks its very bright and shows the lines well. But you have two blue/whites already and a dark green would be great contrast for your collection. Good luck, it will look great no matter whick way you go.
Old 08-28-2011, 02:12 PM   #274
wutnxt
Thanks man
Yea i like that last blue truck that i did blue alot.....and i am really not a blue kinda guy so thats wierd. The shortbox truck beside it i just sold to my buddy so i can still see it...drive it...but not have to fix it...lol
Ya that Dino.....His truck looks great....it's a killer......his will be done before mine i am sure. He seems like a really cool dude too...( Dino that was just for you buddy ) So there is no way i would use the same color he wanted to ...or the same lawn mower engine he is...chuckles.
But I think if i can find a nice silver i will do the frame and under cab all in silver i think. I was going to powder coat the frame, but i think i will fill it and do body work to it so that it's smoother and cleaner now
Old 08-28-2011, 04:15 PM   #275
CVA59
I'm so freaking jealous right now, LOL. Looks awesome !!! Keep the pics coming.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
