Originally Posted by rocking chevy
So can you fit 35 inch tires right now with the 4 inch lift spindle? I was just wondering because I know fabtechmotorsports.com has a 7.5 inch lift spindle, so if you can fit 35s, then the 7.5 could probably fit 37s, otherwise if you can only fit 33s, then the 7.5 could probably fit 35s. Im just trying to figure this out so I know what all I want to get when I do mine.
The only thing I found from Fabtechmotorsports was a 7.5" lift kit that consisted of lowering the lower control arms for a 88-98 c1500 and using a taller coil along with the 4"lift spindle. Maybe I didn't look in the correct spot. If you found something else can you post a link?
