Old 08-24-2011, 10:39 PM   #1
pritch
pritch's Avatar
68 grill prep question
If you had it down to this:
Would you go ahead and drill out the rivets that hold these last 2 pieces on, the piece that the park lights mount to and the upper one. (I guess I don't know what they are called) and if you did take them off, would just normal pop rivets be OK to hold them back on with? Seems to me it would sure be easier if they were separated.
Thanks for your opinions
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 08-25-2011, 12:00 AM   #2
lil hoodlum
lil hoodlum's Avatar
Re: 68 grill prep question
Yeah that would probably be the thing to do; separate the two parts. (But I will admit, I probably wouldn't do it but that just because I'm lazy)
Keith
lil hoodlum is offline   Reply With Quote
Old 08-25-2011, 09:03 AM   #3
bigsnookmaster
bigsnookmaster's Avatar
Drill it out, and use pop rivets to replace. That's what I did. No problem.
bigsnookmaster is offline   Reply With Quote
Old 08-25-2011, 08:53 PM   #4
pritch
pritch's Avatar
I went ahead and did that very thing for practice (on an older grill that's headed to the scrap heap) and discovered that the pieces are interchangeable, I mean if you didn't want park lights, or want them in the top one, or whatever. I was surprised that they are the same.
'68 Panel
'68 C-10
Ol' Green
Old 08-25-2011, 09:05 PM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
Yes I would take it apart and did for my build. I think LMC Trucks makes rivet headed bolts to reattach the grill surrounds to the grill.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 08-25-2011, 11:53 PM   #6
extd56
extd56's Avatar
They do make the rivet head bolts to reinstall them. I put the blinker on the top in my crew cab and took out the blinker in the extended cab.
extd56 is offline   Reply With Quote
Old 08-26-2011, 12:08 PM   #7
jaros44sr
jaros44sr's Avatar
Just did the same thing to mine, was surprised to see bare metal once i took it apart
BTW, Wes at classic heartbeats has new grille hoop trim clips, if you need them
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-26-2011, 08:58 PM   #8
pritch
pritch's Avatar
Good to know. Sure enough, I'm gonna need some more at a later date.
Thanks, jaros
'68 Panel
'68 C-10
Ol' Green
