Old 08-21-2011, 12:34 PM   #1
Hazieview
Building Dreams out of Dimes!
Will trailing arms from a '66 chevy short wide fit on my '81 short wide?
Hey guys I was wondering if the trailing arms off of my old '66 short bed would fit on my '81 short bed. It sure would save me a lot of money.
I would also like to use the crossmember if I could.
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 08-21-2011, 01:24 PM   #2
80streetcoupe
Re: Will trailing arms from a '66 chevy short wide fit on my '81 short wide?
I've never done it before, although years ago I did think about it. Get out a tape measure and start taking down measurements. I am sure some welding and manufacturing may be required as well cuz you are mixing parts from different yrs.
Just my 2cents werth!!
80streetcoupe is offline   Reply With Quote
Old 08-21-2011, 02:14 PM   #3
higgiec10
higgiec10's Avatar
check this out
http://www.porterbuiltfabrication.co...-for-73-87-C10
higgiec10 is offline   Reply With Quote
Old 08-21-2011, 02:22 PM   #4
Hazieview
My '66 has everything that kit had! Looks like I need to bust out the tape measure and torch!
SB400 350th
Old 08-21-2011, 11:16 PM   #5
Magnimike1
CPP makes a retro kit also if you didn't know.
Magnimike1 is offline   Reply With Quote
Old 08-25-2011, 01:08 AM   #6
Hazieview
I really don't to buy anything else. I was just wondering if anyone attempted to put the '66 traling arms on a square body or if anyone sees why it may not work.
Thanks for any and all feedback guys!
SB400 350th
Old 08-25-2011, 08:55 AM   #7
k5warwagon
k5warwagon's Avatar
I asked that very question (only I said 67 to 72 trailing arms) on the "Make It Handle" thread. Rob at no limit said go for it.
1987 C-10 Stepside shortbox project "Rosie"
Lee W
k5warwagon is offline   Reply With Quote
Old 08-25-2011, 08:58 PM   #8
Hazieview
I think I will try it out. Is anyone here even running trailing arms?
SB400 350th
Old 08-25-2011, 11:00 PM   #9
67_SS396
Not yet, but if I decide not to do a one link, then I will swap in a set of trailing arms. That swap is way down the road though. If you have the tools and fabrication skills, it shouldn't be too tough of a job, just time consuming.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 08-25-2011, 11:25 PM   #10
SCOTI
SCOTI's Avatar
There's a couple of members trucks that have done the swap using a 'kit'. I can't recall any that did the swap making their own x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-26-2011, 10:18 AM   #11
Jonboy
Slots go on anything!
I would at least buy a crossmember. They are inexpensive enough that the money spent would be way ahead of cutting out and modifying one to go in. Porterbuilt bolt in crossmembers with a lot more adjustment are only $349. The ones from Early Classic and Performance are less expensive than that, but don't have the range of adjustments.
Yeah, leaf springs are not very popular in that thread.
I have been doing quite a bit of research lately, with Scoti's help. I am just about there, but debating on brakes and wheels/tires before I pull the trigger.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-26-2011, 10:54 AM   #12
SCOTI
SCOTI's Avatar
Classic Perf Parts & Porterbuilt are the only 2 manufacturers building a 'bolt-in' swap kit for installing truck-arms into 73-87 leaf applications. Hot Rods 2 Hell makes a universal/truck kit that's a weld-in.
From my research, you can't just slide a 63-72 T/A x-member between the rails of the 73-87 & expect it to work. The rear portion of the frames kick up @ different locations so the x-member actually would need to be set-up so it goes on the bottom of the frame vs. between the rails like 63-72's.
Of the 'kits' offered, Porterbuilts set-up offers the greatest flexibility in articulation & adjustment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-26-2011, 11:31 AM   #13
Jonboy
True. The ECE crossmember states it is for pre '73 trucks, the one from Performance Online comes up in a search for '74 parts, but may be pre '73 as well. The PB crossmember is a really nice tubular work of art. I really like it.
Old 08-26-2011, 04:10 PM   #14
Hazieview
My biggest hold up on the whole deal is this:
A bolt in parallel 4 link is WAY expensive imo.
A triangulated 4 link is cheaper but will have to be welded in permanently.
Trailing arms would possibly be free in my situation. As long as the modification did not have to be too great.
It should be pretty simple to see if they won't work at all. I just need to take both beds off and compare measurements. If it does not work then I didn't lose any cash at all..
Just thinking out loud.... I was hoping someone would tell me they would not work! It sure would save me some time.
SB400 350th
Old 08-26-2011, 04:14 PM   #15
Jonboy
The arms themselves should work just fine. If you are going to do this, you will need to put the correct mounts on your rear axle, and get a trailing arm crossmember. If you are going to lower it as well, I would look at the PB setup (and just get the arms from him also).
Old 08-26-2011, 04:39 PM   #16
SCOTI
SCOTI's Avatar
Trailing arms would possibly be free in my situation. As long as the modification did not have to be too great.It should be pretty simple to see if they won't work at all. I just need to take both beds off and compare measurements. If it does not work then I didn't lose any cash at all..
The T/A's will work well in a 73-87, just like they did from 63-72. The key item is locating the front pivot point as you cannot utilize the factory T/A x-member because of the difference in frame kick-ups. The other mounting obstacles will be:
the upper spring mounts
upper/lower shock mounts
Panhard bar mounts (frame & rear end housing)
Would this suspension set-up be easier to install vs. a 4-bar set-up? They both have obstacles that would require fabrication or higher costs for 'kit' parts to ease installation. Whether it's easier and/or cost effective vs. the 4-bar install would be subjective to the guy doing the work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-27-2011, 12:25 AM   #17
67_SS396
Grab some steel, fire up the plasma and the welder and get to it! If I come across a set of arms cheaper than I can buy the steel to do a one link, I've talked myself into making this my next project after getting the truck running. If you didn't have the arms available cheap, you can always make your own. I like four links, but they can be a pain to dial in.
RevLimit Offroad
Old 08-27-2011, 12:31 AM   #18
SBTork
Garage wrench
SBTork's Avatar
Originally Posted by higgiec10 View Post
anyone know if this will fit a 'burb?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 08-27-2011, 02:37 AM   #19
68c10owner
68c10owner's Avatar
Man I really like the porterbuilt set up. Definatly something to think about for the future. Anyone know if it`s going to be available with regular coil springs or is it air bag only?
Anthony
68c10owner is offline   Reply With Quote
