Old 08-26-2011, 10:51 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How Low should I go on my 66??? 2/4", 3/5", 4/6"?
el_bole my memory gets a little sketchy on the early 60 rears so I may not be 100% correct here. From what I recall the 61's had an older style 12 bolt that is not compatible with the later 63ish 12 bolts.
You can have your current axles hubs redrilled for 5x5, or buy new axles with the 5x5 pattern for your current housing. Converting to a later axle gets the job done too, but will require some mods. The 73+ axle will be leaf spring vs trailing arm's and coils.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-27-2011, 02:01 AM   #2
el_bole
Thanks for the info!!! Yeah I am in the process of getting a '73 rolling chassis with front and rear suspension so Im wanting to swap out both...
Yes my '61 is 12 bolt but not posi unfortunetly,,,I am def. going to look into all my options before I dive head long into this project...
Thanks again
el_bole
el_bole is offline   Reply With Quote
Old 08-27-2011, 04:46 PM   #3
SCOTI
SCOTI's Avatar
Pre-65's have the weaker 17-spline axle 12-bolts or the old style 'drop-out' rear ends that resemble a 9". The post 65 12-bolts should be 30-spline.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
