![]() Join Date: Jan 2002
Front Blazer seats
What are you guys using for front seats in your blazers. I have looked at a lot of aftermarket stuff and always run into rear seat access issues. Is anyone using seats out of a newer blazer. If so can you use that mounting bracket. I know I can use the original brackets because I have high back Jeep buckets mounted to them. Just wondering what everyone else has done.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
go cyclones
seats
I have gotten seats out of a new 2002 Silverado and currently looking for a third seat out of a Suburban or Tahoe. I like the new seats because they have the integrated three point seat belts. As far as rear seat access, currently I have 1999 Jeep Grand Cherokee seats in my truck. On the drivers side I just used the original jeep seat bracket and modified them to fit. On the passenger side I made an adapter to mount to the existing blazer seat hinge. It worked all right a little crude though. One thing I am going to look at when I install these new seats is the sliding mechanism off the late model f*rds. Yeah I know it’s the enemy but the extended cab f-150s have a flat floor with a slide on there seats that will move the seat all the way up to the front so you can easily access the back. Well enough of my run-on sentences.
![]() Join Date: Apr 2000
i`m using a set of s-10 blazer seats on factory brackets,a couple of the holes lined up and i just drilled a couple in the seat frame,that was it.
and i can always go back to stock frames cause i didn`t modify them. and they are cheap!!!!
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
i am using fiberglass buckets its tight but a little work and they will fit great i love them i take the covers off if it rains then wipe the seat off and put them back on
72 cst 2wd blazer sb soon to have tilt manual 72 gmc swb fleet 2wd bb air tilt auto 93 c/3500 crew-cab dually 03 chevy suburban LT quadrasteer c/2500 4x4 |
I have a set of 72 dark green ones that need covers in chico calif
