Old 08-28-2011, 09:14 AM   #1
mikeesracing
mikeesracing's Avatar
Re: tail light/electrical problem
Make sure you have a good ground for the whole bed. I had loose bed bolts once that kept all of the tail lights from working.
If the voltage is present until you put a load on it it is most likely you have a bad wire (freyed or chaffed) that gives you continuity but will not carry the amps.
mikeesracing is offline   Reply With Quote
