Old 08-10-2003, 01:18 AM   #1
crackajacka
Stylin
crackajacka's Avatar
i know this is kinda stupid but
how do u tell the gear ratio of a rear end?
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 08-10-2003, 02:57 AM   #2
77K20
From what I have been told, and have read, the easiest way is to jack up the rear-end. Then make a mark at the top of the tire, and on the driveline. Rotate the tire 360* and count how many times the driveline turns.
i.e: Driveline makes barely past three rotations= 3.08
Driveline makes 3 1/2 rotations= 3.56
Driveline makes barely over 4 rotations= 4.10
You get the idea. Or you could also remove the differential cover and start counting teeth.
Someone correct me if I'm wrong, but this is what I have been told, and this is what I do.
2-Knee
p.s. make sure to block the front tires so your truck doesn't go anywhere.
77K20 is offline   Reply With Quote
Old 08-12-2003, 12:50 AM   #3
jimfulco
That works on a posi, but on a peg-leg, jack up only one side, & turn the wheel TWO turns while you count the driveshaft revolutions. Both sides up on a peg-leg will give you a false reading. Not a bad idea to chock the front wheels before you do this.
jimfulco is offline   Reply With Quote
Old 08-13-2003, 11:18 PM   #4
Grey 87
Pull your diff. cover off and count the teeth on the ring gear and the pinion gear. Divide the ring gear number by the pinion gear number and you will have your gear ratio.
ring gear =41
pinion gear=11
Your gear ratio will be 4.10
Grey 87 is offline   Reply With Quote
Old 08-13-2003, 11:32 PM   #5
love it loud
Calibration Engineer
love it loud's Avatar
41/11 is 3.73
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 08-13-2003, 11:34 PM   #6
Grey 87
ring gear =41
pinion gear=11
Your gear ratio will be 3.73
87 SWB Silverado
84 LWB Custom Deluxe
Old 08-13-2003, 11:36 PM   #7
Grey 87
What a Maroon! Thanks for the correction.
87 SWB Silverado
Old 08-13-2003, 11:45 PM   #8
crossy
Oh,you can't buy that new
crossy's Avatar
If you don't feel like pulling the cover then use a file to clean off the top of the passenger side axle tube and you'll find a 3 letter code there. I know or can find most of them. 75% of 81-86's 2.73 ratio. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 08-13-2003, 11:45 PM   #9
swervin ervin
You get what you pay for
swervin ervin's Avatar
From what I've read on all the parts catalogs I have, there is supposed to be a code stamped on the axle tube, about 3-6" out from the carrier, on the passenger side, front. I haven't looked at either of my trucks or van, but the catalogs give the ratios for the codes.
I need to check into this some more and see if I can find one. Anyway, if anyone does find a code, I have the books to tell you what it came with.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-14-2003, 01:08 AM   #10
PHOENIX
I just went and looked at my rear axle. I didnt find any numbers on the tubes at all. But I did found the following on the pumpkin.
Passenger side:
GM32
Driver Side:
1254333
B43
Does that tell you anything?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 08-14-2003, 05:55 AM   #11
crossy
crossy's Avatar
remember that those numbers were stamped by humans so they could be off a little. I just went out and checked the 86 K5 I am parting out and they were right there.they tend to on the very top down to about the 2 o'clock position on the tube. my 3 letter code was first then all the part number rubbish that means other things. It's always there. like i said a file seems to work best for me . If it is grimey I use a putty knife. the only ones i have not been able to find it on are ones that are badly rusted.
On your 86 it will most likely start with an A,B, C or H and can havea number in there also.
Those numbers you found were part numbers for the center section and it's date. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 08-14-2003, 09:45 AM   #12
messed up c-10
RHCP afficianado
messed up c-10's Avatar
Does your truck have a three speed or a four. You could probably find the factory specs. for an 86 from someone on the board. If your truck is mostly stock then I would guess that your gears are probably stock too. If you have a three speed I would bet that you have 2.73's if a four speed then maybe 2.73's or 3.08's.
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 08-14-2003, 09:52 AM   #13
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
FINALLY!! Someone gave me the answer to the question I have asked everyone for the past 3 years!! haha Peg leg reading with both wheels up is crazy!! lol Thanks man!
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 08-14-2003, 12:06 PM   #14
PHOENIX
Are the numbers stamped into the tube or are the numbers raised?
I plan to open up the diff. cover pretty soon eitherway to check it out and change the gear oil (probably this weekend).
Old 08-14-2003, 01:55 PM   #15
swervin ervin
I never knew these numbers existed until I started buying original GM Parts and Illustration catalogs. These things are great for helping to find part numbers and identifing parts for our trucks.
Anyway, I looked for the numbers on my van and couldn't find any. I checked the 85 and did find those. They are small, about 1/8" in size and like Dave said, they were stamped by hand. They used a die set to do it with so they are not deep at all. You have to look real close and have some bright light. Mine were about 6" out from the carrier, on the passenger side, almost dead center on the front of the tube.
The code on my 85 was BX3. This translates to:
2.73 ratio, 11.15 x 2.75 brakes, Exc. G80.
Happy searching.
Oh, if anyone finds their code and wants to know what it means, I'll be glad to look. Although I haven't looked at them in great detail, I have catalogs for all years of our trucks, even vans.
Mike
Old 08-14-2003, 05:03 PM   #16
Prerunner1982
Prerunner1982's Avatar
i attempted to look but entire axle is covered in crap... so after some cleaning i will look again!
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-14-2003, 08:29 PM   #17
PHOENIX
I found them now.
I had to look a little closer.
TWA G040
Old 08-14-2003, 09:34 PM   #18
swervin ervin
Eddie,
you are not going to believe this, but your truck falls into a catalog I don't have.
I have a 73-78 Parts catalog, 79-84 Illustration catalog, and 85-86 CK, 87-89 RV Parts and Illustration catalogs. But no 79-84 Parts catalog. I need to find the 73-78 Illustration catalog and 79-84 Parts catalog.
The Illustration catalogs don't have the codes, only the parts catalog. I found a 79-84 Parts catalog on ebay, but it is pretty ragged, so I think I'll pass on it.
http://cgi.ebay.com/ebaymotors/ws/eB...category=34216
Sorry, but I tried.
Old 08-14-2003, 09:43 PM   #19
PHOENIX
Thats OK, anyone else have a book?
I will probably open the rear end this weekend anyway.
