Old 08-29-2011, 06:57 PM   #1
jimmydean
jimmydean's Avatar
bedside removal.
So everything is unbolted and it looks like the only thing holding it on is a small spot weld in the corner from the bedside to the rear cross sill. So if I cut it off, is that all it takes? Or is there something I'm not seeing.
This is silly.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-29-2011, 07:13 PM   #2
chad64chevy
chad64chevy's Avatar
Re: bedside removal.
ya the small spot weld sholud be all as long as everything is unbolted!! did you unbolt the four bolts that bolts the rear sill to the bed side??
chad64chevy is offline   Reply With Quote
Old 08-29-2011, 07:17 PM   #3
jimmydean
jimmydean's Avatar
The 4 really rusty and not all that easy to get to with any of my tools, bolts? Yes, I think I got them all.
Thanks, I will grind and see what falls off.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-29-2011, 09:54 PM   #4
Slow Build
Slow Build's Avatar
I've heard there are two welds on each side. One on top of the rear sill (horizonal)and one at the bottom (vertical).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 08-29-2011, 10:01 PM   #5
Slowtruk
Slowtruk's Avatar
Is there any way of marking those welds to ensure proper re-alignment when you put i back together? Like drilling an 1/8" hole through it to align them back up with?
Slowtruk is offline   Reply With Quote
