08-22-2011, 01:21 AM | #1 |
How do you hook up a later horn to a '71?
My steering wheel hub is cracked, so i decided to get a replacement wheel. I wound up getting one off a '71 Chevelle. How can I adapt the horn spring to let the horn work with this wheel?
08-24-2011, 03:30 PM | #2 |
Re: How do you hook up a later horn to a '71?
i thought this question would be a ground ball for the experienced brothers we have on here.
08-24-2011, 03:40 PM | #3 |
You need to find horn contact wire. It is a black wire with a plastic fitting that locks into the contact ring and keeps tension with a spring. The other side will clip onto that tab.
As far as where to find one - I don't know.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
08-24-2011, 03:56 PM | #4 |
Its a Truck Thing......
I have one off the exact same wheel, send me your address and I will mail it to you free...You will need to get the horn contact that lets it push in and turn into the notch to make it work.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
08-25-2011, 12:51 AM | #5 |
Well, after wasting a couple of hours staring at this thing, the beer fog wore off, and i rigged it up temporarily until brother Smitty sends me a piece.
I know alot of you guys dont like this wheel, but it only cost me $40 at a swap meet and there are no cracks, and the smaller diameter makes it have greater clearance to work under the dash. |
08-25-2011, 01:08 AM | #6 |
This thread was quite helpful actually, I have a wheel out of a Nova and the horn doesn't work and now I know why. I think that style wheel looks good in the 67-87 trucks. What size is that one, my is about 2" to big.
-Justin. The past cannot be edited, or erased. Only accepted. Loud, proud and country by the grace of god! Bradley Anderson 1997-2011 |
08-25-2011, 07:39 AM | #7 | |
Yeah, my stock truck steering wheel is just too big. This one looks big in this photo, but it is the size of a standard american car steering wheel, and it is much better. |
08-25-2011, 11:21 AM | #8 |
I also liked that it is flat rather than dished. I also have this same wheel. Too bad I can't find the center part or I'd let it go cheap.
08-29-2011, 11:12 PM | #9 | |
I used my Dremmel tool to cut a notch in the tube for the black plastic piece to lock in. Thanks for taking the trouble to send me the piece. It is good to see brothers helping out each other many states away, I appreciate the help. Joe |
