08-29-2011, 11:06 AM | #1 |
68 disc brakes
I have a 68 that I would like to convert to disc brakes...I have an 82 donor truck, and I would like to put dropped spindles on it. Does anyone know if the 82 parts will work with any of the aftermarket spindles that are out there?
08-29-2011, 12:27 PM | #2 |
67-72 parts collector,…
Re: 68 disc brakes
Buy 73-87 spindles and you will be fine.
BUT,... make sure you measure the width of your rotors before you order. There are 2 different spindles. They make spindles for HD 1-1/4" wide rotors and LD 1" wide rotors. (heavy duty and light duty)
08-30-2011, 10:49 PM | #3 |
Hellasick
Re: 68 disc brakes
Make sure you use the '82 center link too, then you aren't mixing the tie rod ends. The center link will bolt right up to the pitman arm just fine.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
