Old 09-01-2011, 05:55 AM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: labor knock turned into major pain!
check the oil see if you can see bearing material silver ,drain the oil and take a flashlite and check to see if you got metal flake in the oil ,main and rod bearing worn out ,knock will get worst ,changing the cam and lifters did you change valve springs ?
i would check the timing if you got the dizzy off timing .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
knock, loss of power
