Old 08-31-2011, 06:56 PM   #1
JRBECK64
700R4 in a 67 pickup
Do you have to change out the stock cross member to run a 700r4 Tranny? The truck had a TH400 in it originally. Thanks for any help with this.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 08-31-2011, 08:34 PM   #2
hugger6933
Re: 700R4 in a 67 pickup
You should have no problems mounting the 700R4 with that crossmember. You will however, have to move it to a different location on the frame rails. I am planning the same with my 68 short 454 truck that is currently under construction. P.S. Don't forget to get the tv cable adjusted properly or it could be bad news[ if you have'nt had one before] .Jim
hugger6933 is offline   Reply With Quote
Old 08-31-2011, 09:30 PM   #3
nightmare
nightmare's Avatar
I left the crossmember in the stock location, and just added a plate to move the mount to the new location. Mine had a TH400 originally as well.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 09-01-2011, 02:36 PM   #4
JRBECK64
Thanks for the info. That will be helpful. When I put one in my Sons 64 Shortwide I had to get a different crossmember and it was kinda spendy so Im glad I dont have to be out that money.
JRBECK64
Old 09-02-2011, 12:26 AM   #5
LEEVON
Moderator
LEEVON's Avatar
Two things to think about...
  • the top bolts on a stock crossmember to frame are a pain to remove and replace, drilling new holes up there is not easy.
  • accessing the rearward pan bolts on the 700r4 is very difficult if not impossible on stock crossmembers.
For $40 or so a CPP tubular crossmember is a good deal if the above are important to you. It bolts on the bottom flange of the frame only and allows access to pan bolts.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-02-2011, 07:43 AM   #6
JRBECK64
Thats a really good point, and being that I like to do my own oil changes I would probably be kicking myself later. Thanks for the info.
JRBECK64
Old 09-02-2011, 11:14 AM   #7
funkytechmonkey
funkytechmonkey's Avatar
Porterbuilt has a nice tubular crossmember too. Great guys to work with and less a headache than CPP. Go with porterbuilt.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 09-03-2011, 07:38 AM   #8
JRBECK64
Crossmember is on its way and even bolts in the same holes as the ones that are in the crossmember thats in it now. Thanks again for all the info.
JRBECK64
