Closed Thread
Old 09-01-2011, 09:12 PM   #3801
RUSHNBOBO
Re: What did you do to your truck today?
Originally Posted by pdxhall View Post
I went to Harbor Freight and bought one of their $40 HVLP guns (I figured it was good enough for the chassis) and did my first spraying with an HVLP. I love this thing.
Dude I've got the same gun for non critical areas ...for the price you can't beat it ...consistent spray pattern, good atomization and best of all cheap
How much were those shocks, and are they single or mono tube?
RUSHNBOBO is offline
Old 09-02-2011, 12:08 AM   #3802
towersddg9
towersddg9's Avatar
Put my 12bolt back in, finally got it finished
towersddg9 is offline
Old 09-02-2011, 12:45 AM   #3803
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Bought a replacement cab.
Picking it up tomorrow.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 09-02-2011, 10:17 AM   #3804
kieth
kieth's Avatar
Drove the gmc everywhere, worked on the tailgate........
kieth is offline
Old 09-02-2011, 06:39 PM   #3805
lakeroadster
Did a bit more work on developing the technique for the fauxtina on my stepside bed. The bed had shiney spots from the areas that were low and didn't get sanded. I used my hand finishing sander with a green Scotchbrite attached. This helped, and was quick and easy, but there was still some gloss. I then used some full strength degreaser (Purple Power) and simply wiped it on with a shop rage, then removed it with a dry shop rag. That did the trick and was also pretty easy.
So the technique is now defined, now I just gotta find the time to do the rest of the truck I am sure most of ya would agree that working for a livin' is way over-rated.
(if your curious about primer and how it was applied check out my build thread. The primer application is the key to the look)...
This last photo shows the lack of gloss of the "finished" product. The faux-tina process isn't for the faint of heart, once the gloss coat is sprayed over the rolled on primer the paint looks hideous. The sanding, scotchbrite and chemical de-glossing brings it back to some level of decency... well arguably so. I know a lot of people hate it. That's ok, variety is the spice of life and I gotta tell ya'll I am having a grand ole time working on this.
lakeroadster is offline
Old 09-02-2011, 07:51 PM   #3806
nachodog2
Hell yeah!!!
nachodog2's Avatar
Got her washed up and ready to take an early morning drive to the ventura nationals.
Stock is good but custom is the sh*t!
nachodog2 is offline
Old 09-02-2011, 10:23 PM   #3807
64shortbox
64shortbox's Avatar
Smile Re: What did you do to your truck today?
Not a heck of a lot. My supervisor took half the day off so I brought in my passenger side inner fender in to work so I could pressure wash, media blast and weld up all the factory and PO's holes. Unfortunately after pressure washing I discovered that the inner fenders were undercoated in places so I couldn't media blast it. I have to go after it with the heat gun and a putty knife first. I plan on getting one of those $170.00 - 22 circut wiring harnesses off eRape and running my wiring down the inside of the frame rails. That way I can run an internally regulated alternator, get rid ot the voltage regulator, move the horn between the grille and the radiator support and mount a NOS radiator over flow bottle that I have for a 71 Cadillac. It should fit perfect. I'm actually looking forward to going to the graveyard shift for the next 3 months. I plan on getting a LOT done on my truck durning that time as long we have no major break downs at my work while I'm on graves.
I'm pretty lucky. At my work they have a 100 TON press, 1 Bridgeport mill, 1 steam cleaner, 2 pressure washers, 2 TIG welders, 2 arc welders, 3 MIG welders, 2 lathes but one is down right now, 1 band saw, 1 chop saw, etc, etc. they should know better than leave me unsupervised during a shift.
64shortbox is offline
Old 09-02-2011, 11:08 PM   #3808
Chvyman1975
Chvyman1975's Avatar
lets see...a few nights ago...i painted the engine bay and the motor. today i put the 22's on it. i think im going to have to change the rear wheel studs...they are not long enough....
Chvyman1975 is offline
Old 09-02-2011, 11:13 PM   #3809
Wildcats_95
Wildcats_95's Avatar
I replaced the 5 1/2 year old dry rotted tires so I can now roll it in and out of the hobby shop. Let the games begin tomorrow with the tear down process.
Wildcats_95 is offline
Old 09-03-2011, 01:35 PM   #3810
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Well not sure this really counts but.....I opened up the new boxes for the prostreet build.....and well it's a great day.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 09-03-2011, 02:00 PM   #3811
skysoldier173rd
skysoldier173rd's Avatar
Been wanting to get into airbrush for a long time. This is my first attempt. It's easier than people think, just get some stencils and you can play to your hearts content. I think i'll try some flames next.
skysoldier173rd is offline
Old 09-03-2011, 04:14 PM   #3812
losthope
losthope's Avatar
IT"S ALIVE!!!!!The engine i pulled out of the wrecked 65 fired up in the 66 ,i ran it for about ten minutes ,still have to tune carb and set timining but it ran!!!!need to find some tires that hold air so i can see if the used tranny works or not....and i had a extra gas tank for my 54 ford sedan,that i did ruff measurements on and should fit right inbetween frame rails no problem its a 17 gallon ,still need to find out the ohms for sender.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 09-03-2011, 05:59 PM   #3813
awbrown
Well , I got the engine in the 63 today .. It would like to have killed me .. Every thing had to be reworked nothing went together like I had hoped it would ,missed the fact there was a broken bolt in the rear of the head so the last header bolt will have to wait .. I found one like it on the left side before dropping it in and it was an easy one to remove .... the P/S works , I ran it for a minute , no leaks , it is charging ,so all I have to do is finish weld the steering shaft and install the new radiator...
awbrown is offline
Old 09-03-2011, 06:11 PM   #3814
wutnxt
Sounds like a very busy day dude
wutnxt is offline
Old 09-03-2011, 06:57 PM   #3815
towersddg9
towersddg9's Avatar
Rolled outside this morning, first time on all for tires since last November
Old 09-03-2011, 09:06 PM   #3816
Wildcats_95
Well, it's a start but here is what my father in law and I accomplished today.
Old 09-03-2011, 09:24 PM   #3817
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: What did you do to your truck today?
Little bit more progress today.
Not bad from a couple of country boyz huh.........
Dang I am tired..........
I'm going grab a glass of sweet tea, watch some TV, and go to bed.
Can't wait to get this dang truck done!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 09-03-2011, 09:46 PM   #3818
Wildcats_95
Wow! I thought I had a good day working on my truck...looks like you just killed me in the progress category.
Old 09-03-2011, 10:04 PM   #3819
1Bad62Pro/Street
Ha ha...
I started around 8am -- 8pm... off and on.
It was hotter than an electric prod on a hog's behind outside.
Took many breaks!
Old 09-03-2011, 10:09 PM   #3820
Wildcats_95
Well that would explain it. I only worked about 3-4 hours on mine today.
Real nice truck!
Old 09-03-2011, 10:51 PM   #3821
Vernski
Originally Posted by 1Bad62Pro/Street View Post
Ha ha...
Took many breaks!
Hey Bud finally got the box on now that's progress, that is one cool truck and that's the color yellow I like the most. What's the plan for the bed floor?...Vernski
Vernski is offline
Old 09-03-2011, 11:08 PM   #3822
1Bad62Pro/Street
Take a gander at my build thread bud:
The Shiney Stuff.......
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Old 09-03-2011, 11:35 PM   #3823
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
[QUOTE=1Bad62Pro/Street;4880215][B]Little bit more progress today.
Please don't take my question wrong but I am curious as to why you are fabing up such big wheel tubs when the top and sides of the tire don't come anywhere near the top of the tubs?
Do you have an Air Ride setup or something that will take the tires up further in the wheel tubs.
Again, just curious.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 09-04-2011, 12:06 AM   #3824
Rich 5150 69
Rich 5150 69's Avatar
What are the measurements for that tank losthope including the flange that extends out on the sides...Thanx
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 09-04-2011, 12:10 AM   #3825
shrunken66stroker
shrunken66stroker's Avatar
[quote=66-PMD-GMC;4880462]
You ever seen the top fuelers when they nail it and the tires get real tall???
shrunken66stroker is offline
Closed Thread
