Needed: pics and info on lowering..
Coil rear suspention and blocks,, need pics of what it looks like under neath and a side shot of truck
so i can see what it might look like size of blocks you used and etc Thanks
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ ![]() ![]() |
3 inch blocks, sorry I dont have a shot of them under truck.
You can see a picture of a two inch block installed at the web site below
http://www.classicperform.com/goingdown6772.htm
On the eighth day, he made trucks and saw they were good. |
Gene
Can you tell me what the height is from the ground to the center of the whell opening arch, front ans rear? That's about the stance I'm after, and I need so see what blocks to buy. Thanks. TF
Front measures 28 inches rear is 29 1/2 with 3 inch blocks and one coil cut from the front springs, on 295/50/15 inch rims.
67-72 Addict!
Gene, I love that stance man!. Just right!!!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
senior member
Gene how much is your front lowered?
69 GMC bagged |
