total fluid capacity of TH350-c trans. ?
Can't find the total capacity. I have read in alldata 10 quarts. My owners manual says 5 quarts which I think is refill. I am installing a rebuilt trans in my 86 c-10 305v8 with a350 th-c and I know I need to put at least 2 quarts in my new torque converter. Any help is much apprec. Thanks
The One And Only !!!
Re: total fluid capacity of TH350-c trans. ?
My BIG Chilton's shop manual states 10 qts dry...... 4 qts for fluid and filter change only.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
I'm pretty sure it's only about 4qts. That sounds about right
In the Forgotten far North.
![]() Join Date: Jul 2007
For a totally dry TH350 tranny it'll hold 12 qts with the standard torque convertor... If you install a torque convertor from a TH400 you can increase the amount to 14 quarts. Done this a few times in the past.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
![]() ![]() Join Date: Jul 2002
GM manual says 20 pints if dry. I just finished putting a new T350-C in my 83 and with the extra deep sump pan it took 12 qts.
