Old 09-02-2011, 08:24 AM   #1
no moa
no moa's Avatar
Frames
I posted locally on CL i need a 70-72 chevy gmc shortbed frame,trailing arms, that accomidates power steering.
I already had one guy say he had a 70 frame, but it was under a 78 truck with leafs. morons.
Are there any differences in the 70-72 then the newer? I know alot of guys have used newer frames up to 77 or so?
I need a good frame for the stepper with PS. Mine has none. I don't want to end up with something wrong.
Thanks guys.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 09-02-2011, 08:32 AM   #2
m6z
m6z's Avatar
Re: Frames
Thanks guys.
Somthing wrong with your frame? Why not add ps to your frame? The 68-72 frames are all the same and the only difference on the 67 frames is they don't have the dimple for the ps, but you could always add that if you wanted to(torch and a hammer).
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 09-02-2011, 08:49 AM   #3
no moa
no moa's Avatar
Re: Frames
I thought power steering frames were different than non for 68-72? I guess I am mistaken, I can just add PS to my 71 frame? I haven't pulled it apart yet to see if the dimple is there. But I have a 2wd PS box and pump from a 71 (I think) engine.
Glen
Old 09-02-2011, 08:52 AM   #4
m6z
m6z's Avatar
Re: Frames
Glen
That's the info I've read/been told. I'm sure somone will be on here shortly to confirm or deny what I've said.
Doug
Old 09-02-2011, 08:57 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Frames
it'll bolt on.
The frames changed dramaticly in 73. Longer wheelbase, and a major kick up directly under the cab. A 4X4 can pull it off with a custom body lift and a relocated rear axle. But a 2 wheel drive can't do it. You'll end up with a mostly custom built frame and coulda saved time just going all out and full custom frame.
Old 09-02-2011, 09:45 AM   #6
no moa
no moa's Avatar
Re: Frames
This truck came into work the other day, this is on a 77 frame with power steering i guess. Nice truck!
But that is y i asked the frame questions.
Old 09-02-2011, 11:37 AM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Frames
power steering box should bolt right up to your 71 frame. Po added dimple to my 67 frame.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-02-2011, 12:46 PM   #8
OJ1988
Just a car guy
OJ1988's Avatar
Re: Frames
Nice truck!
Except for the dumb looking bed! I just don't get that.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-02-2011, 10:40 PM   #9
Longhorn Man
Re: Frames
Did you verify it had the claimed frame? It would be a LOT of work to make it work under a 2 wheel drive.
Old 09-03-2011, 07:03 AM   #10
no moa
no moa's Avatar
Re: Frames
I did not, only going by what he said, he told me the frame was junk, and he got a 77 rolling frame for it.
Old 09-03-2011, 07:31 AM   #11
Longhorn Man
Re: Frames
i wonder if he ment he had one to put under it. He'll give up as soon as he puts the cab on
Old 09-03-2011, 09:53 AM   #12
no moa
no moa's Avatar
Re: Frames
If he ever stops in again, i'll take some frame pictures. But he said he did all the work.
